Home » Modeling » EMF » EObject#eSet and autoboxing
Re: EObject#eSet and autoboxing [message #652254 is a reply to message #652229] |
Thu, 03 February 2011 10:36 |
Ed Merks Messages: 33141 Registered: July 2009 |
Tom,
Comments below.
Tom Schindl wrote:
> I've been run into troubles using eSet, primitive values and autoboxing
> (in conjunction with databinding where I was able to fix the problem).
> Suppose you have the following feature:
> -----------8<-----------
> private long myLongFeature;
> public void setMyLongFeature(long myLongFeature) {
> public void eSet(int featureID, Object newValue) {
> switch (featureID) {
> setMyLongFeature((Long)newValue);
> Now the problem is that when databinding under certain circumstances
> converts a String to a number it can happen that the eSet-Method is
> called with an int-value which results in ClassCastException because an
> int is converted to Integer and the cast above fails.
As it should...
> My question now is would it be better if we'd make the eSet get
> generated like this:
> setMyLongFeature(((Number)newValue).longValue());
It's never been the intention for eSet to do any kind of type
conversion. In the case of int you'd do the same, and if you passed a
long that was too big, it would just truncate the value...
> My understanding of autoboxing is that this is more or less what the
> compiler makes from setMyLongFeature((Long)newValue) anyways because at
> the bytecode level you'll get something like this:
> setMyLongFeature(((Long)newValue).longValue());
> This way a call to myinstance.eSet(MY_LONG_FEATURE,10) works like
> myinstance.setMyLongFeature(10).
> So my suggestion would be to make the eSet-code behave like statically
> typed Java method calls in terms of primitive conversion (for types like
> long/double this is as easy as shown above) for other types the
> primitive conversion rules have be taken into account.
I don't think this is a great idea. It makes all numbers
interchangeable in any direction, some of them lossy. That's just not
the intent...
> Tom
Ed Merks
Re: EObject#eSet and autoboxing [message #652256 is a reply to message #652254] |
Thu, 03 February 2011 11:06 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Is it really a conversion when we talk about primitives? Isn't every int
a long - so to any method I can pass a long I'm free to pass an int,
short, char, byte?
> the intent...
This is certainly NOT true for double/long as you wrote "some of them
lossy".
Would it change your opinion when I tell you that Java-Reflection does
what I request here?
> import java.lang.reflect.Method;
> public class TestReflection {
> public static void setLong(long l) {
> System.err.println("Long: " + l);
> public static void setInt(int i) {
> System.err.println("Integer: " + i);
> public static void setShort(short s) {
> System.err.println("Short: " + s);
> public static void setDouble(double i) {
> System.err.println("Double: " + i);
> * @param args
> public static void main(String[] args) {
> // TODO Auto-generated method stub
> try {
> Method m = TestReflection.class.getMethod("setLong", new Class[] { long.class });
> m.invoke(null, new Object[] { 10 } );
> m = TestReflection.class.getMethod("setDouble", new Class[] { double.class });
> m.invoke(null, new Object[] { 10L } );
> m.invoke(null, new Object[] { 10f } );
> //WILL FAIL m = TestReflection.class.getMethod("setInt", new Class[] { int.class });
> // m.invoke(null, new Object[] { 10L } );
> //WILL FAIL m = TestReflection.class.getMethod("setShort", new Class[] { short.class });
> // m.invoke(null, new Object[] { 10 } );
> } catch (Exception e) {
> // TODO Auto-generated catch block
> e.printStackTrace();
So it looks like Java-Reflection has certain rules when it comes to
primitive types when called reflectively.
To a method with:
* double: you can pass Double,Float,Long,Integer,Short,Character,Byte
* float: you can pass Float,Integer
* long: you can pass Long,Integer,Short,Character,Byte
Tom
Re: EObject#eSet and autoboxing [message #652418 is a reply to message #652256] |
Thu, 03 February 2011 19:48 |
--------------000000080702080309020700
Tom,
Comments below.
> short, char, byte?
Well of course the issue is, how does this generalize?
>> the intent...
> lossy".
Actually it's is true for Double->Long.
Not necessarily. Complexity is something that is often best avoided.
So something that's not been an issue for almost 10 years might be
better off left as is.
>> * @param args
>> try {
I guess the question is, what are the rules?
> To a method with:
So conversions that are statically know to be non-lossy... But how to
capture these rules in generated code? Are the subclasses of Number
bounded?
It' seems
> Tom
<html>
<head>
http-equiv="Content-Type">
</head>
Tom,<br>
<br>
Comments below.<br>
<br>
Tom Schindl wrote:
<blockquote cite="mid:iie1s1$9p2$1@news.eclipse.org" type="cite">
<pre wrap="">[...]
</pre>
<blockquote type="cite">
<pre wrap="">It's never been the intention for eSet to do any kind of type
</pre>
</blockquote>
<pre wrap=""><!---->
short, char, byte?
</pre>
</blockquote>
Well of course the issue is, how does this generalize?<br>
<pre wrap="">
</pre>
<pre wrap="">-----------8<-----------
</pre>
</blockquote>
<pre wrap="">I don't think this is a great idea. It makes all numbers
the intent...
</pre>
</blockquote>
lossy".
</pre>
</blockquote>
Actually it's is true for Double->Long.<br>
<pre wrap="">
</pre>
</blockquote>
Not necessarily.
Ed Merks
Re: EObject#eSet and autoboxing [message #652426 is a reply to message #652418] |
Thu, 03 February 2011 20:22 |
Am 03.02.11 20:48, schrieb Ed Merks:
> Tom,
> Comments below.
>> short, char, byte?
>>> the intent...
>> lossy".
I meant there's not potential loss for methods who get passed in a
double or long ;-)
>> To a method with:
> bounded?
I'll try to find that out ;-)
Tom
Current Time: Thu Apr 25 17:59:33 GMT 2024
Powered by FUDForum. Page generated in 5.04290 seconds
