Home » Archived » BIRT » Charts with Interactivity not complete
Re: Charts with Interactivity not complete [message #652169 is a reply to message #652162] |
Wed, 02 February 2011 20:47 |
PNG supports interactivity but not all events/actions that svg does.
Firefox should work with SVG. It does on my system. Also in the
designer you have to enable the svg preview in the options.
Jason
On 2/2/2011 3:04 PM, Klaus Meisl wrote:
> This works better. Above the chart I have another chart (svg), which is
> covered with a white area (see screenshot). When I change that to png it
> works, too. Does png also support interactivity? I can't test this right
> now, because I also discovered another problem: I deployed BIRT and some
> reports on a webserver (see the link below; no access to the webserver
> right now). There interactivity works, but on my laptop it does not...
> OS X
> Am 02.02.11 18:08, schrieb Jason Weathersby:
>> Klaus
>> Can you try png output for the charts instead of SVG?
>> Jason
>> On 2/2/2011 9:09 AM, Klaus Meisl wrote:
>>> Hi,
>>> I get incomplete charts whenever I add Interactivity to a chart. It
>>> seems to be browser-dependable. On Firefox it cut's parts of the chart
>>> (see attached screenshot; not the missing x-axes labels and the chart
>>> cut on the right), on Safari it downloads some "preview" things but
>>> never shows the charts. On Opera 11 everything seems to be fine.
>>> Here's a link to test:
>>> http://pc58545.uni-regensburg.de:8180/birt-viewer/run?__repo rt=Master%2FKlaus%2FMitarbeiter%2Feigene_auftraege_einzelpro zess.rptdesign&__format=html&MitarbeiterID=1&Pro zess=3&__locale=de_DE&__svg=true&__designer=fals e&__pageoverflow=0&__masterpage=true
>>> Only the chart on the bottom has an Interactivity-action (onHover).
Re: Charts with Interactivity not complete [message #652187 is a reply to message #652169] |
Wed, 02 February 2011 22:32 |
Klaus Meisl Messages: 90 Registered: July 2009 |
Member |
"Enable SVG chart" is checked. Does the chart of the link in the first
post work for you? I've asked a friend to test this, he has the same
issue as seen on the first screenshot with OS X and Firefox.
Am 02.02.11 21:47, schrieb Jason Weathersby:
> Jason
>> OS X
>>> Klaus
>>> Jason
>>>> Hi,
Re: Charts with Interactivity not complete [message #652191 is a reply to message #652187] |
Wed, 02 February 2011 23:05 |
Do you mean the pie chart? It shows up but it does not have any
interactivity.
>> Jason
>>> OS X
>>>> Klaus
>>>> Jason
>>>>> Hi,
Re: Charts with Interactivity not complete [message #652271 is a reply to message #652191] |
Thu, 03 February 2011 12:06 |
Member |
i mean the column chart
Am 03.02.11 00:05, schrieb Jason Weathersby:
> interactivity.
>>> Jason
>>>> png it
>>>> right
>>>> some
>>>> OS X
>>>>> Klaus
>>>>> Jason
>>>>>> Hi,
>>>>>> chart
Re: Charts with Interactivity not complete [message #652363 is a reply to message #652271] |
Thu, 03 February 2011 15:59 |
If you mean the bar chart it works fine with interactivity. It appears
to be an svg chart as well.
Jason
>> interactivity.
>>>> Jason
>>>>> png it
>>>>> right
>>>>> some
>>>>> OS X
>>>>>> Klaus
>>>>>> Jason
>>>>>>> Hi,
>>>>>>> chart
Current Time: Fri Apr 19 19:59:25 GMT 2024
Powered by FUDForum. Page generated in 0.04173 seconds
