Home » Eclipse Projects » Equinox » Bundles not getting updated from 'dropins' directory
Bundles not getting updated from 'dropins' directory [message #651905] Tue, 01 February 2011 21:57 Go to next message
I have an installation that uses the 'dropins' directory to load additional plugins. If I first start with, say, version 1.0.100 of those plugins, all plugins are loaded fine. If, however, I add updates to those plugins, version 1.0.101 (so both 1.0.100 and 1.0.101 exist in the dropins directory), then not all of them are getting updated.
The curious (and frustrating) thing about this is that the behavior is very sporadic. Sometimes no plugins get updated, sometimes a few do, and sometimes all of them do. If I manually delete all of the old versions, then everything is loaded properly.
I'm starting with -clean, and can see that the new versions are getting added to the metedata repository in the content.xml file. For some reason the ProfileSynchronizer is deciding to not update some of the plugins in this directory.
Can anyone give me some pointers as to why this is occurring? I'm using Eclipse 3.4.2, but haven't tried recreating this with 3.5+.
Thanks!
-Ryan
Re: Bundles not getting updated from 'dropins' directory [message #652026 is a reply to message #651905] Wed, 02 February 2011 08:30 Go to previous messageGo to next message
/dropins is a best effort, fail silently, just drop it here folder of
last resort.
I was able to find bugs [1] related to this which were fixed in 3.6. It
can still be related to too many optional bundles (SAT4J gets multiple
solutions) but for small numbers of dropins you need the fixes to the bugs.
The other option is to generate p2 metadata for your plugins [2] and
then you can use Help>Install New Software or the director [3] to
install it correctly.
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=301446
https://bugs.eclipse.org/bugs/show_bug.cgi?id=302582
[2]
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/p2_publisher.html
[3]
http://help.eclipse.org/helios/topic/org.eclipse.platform.do c.isv/guide/p2_director.html
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Bundles not getting updated from 'dropins' directory [message #652053 is a reply to message #652026] Wed, 02 February 2011 09:24 Go to previous messageGo to next message
Thanks Paul, this info is in line with the research that I have done as well, but does shed some additional light on why it is occurring.
I had experimented a little bit with generating p2 metadata, but didn't try to "properly" install via the p2 director. Are there any similar known issues with this approach in 3.4.2, or will this generation always find the "optimal" solution with the latest plugin versions?
Thanks again,
Ryan
Re: Bundles not getting updated from 'dropins' directory [message #652064 is a reply to message #651905] Wed, 02 February 2011 09:59 Go to previous messageGo to next message
I also see that a "timeout" property is referenced in some of the bugs, to allow the optimization process more time to find the optimal solution. What is this property, and where is it set? Although I understand that this is not a fix, it would be interesting to see whether it affects the result.
Thanks again,
Ryan
Re: Bundles not getting updated from 'dropins' directory [message #652115 is a reply to message #652053] Wed, 02 February 2011 12:40 Go to previous messageGo to next message
When generating p2 metadata and then installing via the director, it
works a bit differently. The director is tell the profile which
versions to use (deliberately upgrading these n plugins to 1.0.101), and
then SAT4J has to 1) validate the lineup and 2) work out any optionals.
But the plugins in question aren't optional anymore.
The trouble with /dropins is that the SAT4J solver needs to find a
solution with multiple inputs where they're all marked as optional ...
that's a lot of fiddling.
PW
Paul Webster
Re: Bundles not getting updated from 'dropins' directory [message #652161 is a reply to message #652115] Wed, 02 February 2011 14:40 Go to previous message
Thanks again for your insights, Paul. Using the director does seem like a step in the right direction. Unfortunately, though, it seems that the -installIU option only allows me to specify 1 bundle to install in eclipse 3.4.2. I don't have a 'feature group' to use, so I would need to run this command once for every updated bundle to be sure everything is updated.
It appears that newer versions allow a comma separated list, which would be just what the doctor ordered (not sure if 3.5 allows it, but 3.6 does). For now, I guess my answer is either:
1) Delete the old plugins from the dropins directory when new ones are added
2) Update to 3.5 or 3.6, so that either the -installIU option can be used with a comma separated list, plus the aforementioned bugs are fixed.
3) Create a feature group and use feature patching to install bundle updates
Of course, 1) is the quickest for the short term. In the intermediate term, I can investigate 2) and/or 3).
Thanks again,
Ryan
Previous Topic:Helios & Update Manager question
Next Topic:Problem while exporting my product
Current Time: Sun Nov 02 07:45:38 EST 2025
Powered by FUDForum. Page generated in 0.05048 seconds
