Re: Create Report with a Title Page [message #651881 is a reply to message #651873] |
Tue, 01 February 2011 21:04 |
You can create multiple masterpages and then in Page Break property for
a report element set the master page property for the report item.
Jason
On 2/1/2011 3:42 PM, steve.bliss@amway.com wrote:
> Hopefully this is a simple question, but I've not been able to find an
> answer by searching the web --
> How do I set up a report so the first page has one layout, and all
> following pages have a different layout? I assume this involves multiple
> masterpages, but I haven't found how to control masterpage selection by
> page number.
> If it matters, I'm still developing in BIRT 2.3.1.
Re: Create Report with a Title Page [message #652107 is a reply to message #651889] |
Wed, 02 February 2011 17:06 |
One way to do this, if you want the master page to change in a table, is
to add a computed column to the dataset that does a running row count.
Bind a table to the dataset and then filter the table for the row count
less than a value (value should match your page break inveral). Set its
master page to the first master page.
Add a second table that is bound to the same dataset and filter it for
the row count > than the page break interval. Set its master page to
the second master page. See attached report.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.6.1.v20100902 Build <2.6.1.v20100915-1750></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<list-property name="privateDriverProperties">
<ex-property>
<name>contentBidiFormatStr</name>
<value>ILYNN</value>
</ex-property>
<ex-property>
<name>metadataBidiFormatStr</name>
</ex-property>
</list-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="8">
<list-property name="computedColumns">
<structure>
<property name="name">rwc</property>
<property name="dataType">integer</property>
<property
name="aggregateFunction">RUNNINGCOUNT</property>
<list-property name="arguments">
<structure>
<property name="name">Expression</property>
<expression
name="value">row["ORDERLINENUMBER"]</expression>
</structure>
</list-property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
<text-property
name="heading">ORDERNUMBER</text-property>
<property name="displayLength">11</property>
<property name="horizontalAlign">justify</property>
<property name="wordWrap">false</property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
<text-property
name="heading">PRODUCTCODE</text-property>
<property name="displayLength">15</property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
<text-property
name="heading">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
<text-property name="heading">PRICEEACH</text-property>
<property name="displayLength">22</property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
<text-property
name="heading">ORDERLINENUMBER</text-property>
<property name="displayLength">6</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
<structure>
<property name="position">6</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="MP1" id="2">
<property name="backgroundColor">#FF8080</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
<simple-master-page name="MP2" id="43">
<property name="backgroundColor">#FFFF80</property>
</page-setup>
<body>
<table id="78">
<property name="masterPage">MP1</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<text-property
<expression name="expression"
type="javascript">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
<structure>
<text-property name="displayName">rwc</text-property>
type="javascript">dataSetRow["rwc"]</expression>
</structure>
</list-property>
<list-property name="filter">
<structure>
<property name="operator">le</property>
<expression name="expr"
type="javascript">row["rwc"]</expression>
<simple-property-list name="value1">
<value>30</value>
</simple-property-list>
</structure>
</list-property>
<column id="112"/>
<column id="113"/>
<column id="114"/>
<column id="115"/>
<column id="116"/>
<column id="117"/>
<header>
<row id="79">
<cell id="80">
<label id="81">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="82">
<label id="83">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="84">
<label id="85">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="86">
<label id="87">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="88">
<label id="89">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
<cell id="90">
<label id="91">
<text-property name="text">rwc</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="92">
<cell id="93">
<data id="94">
<property name="textAlign">justify</property>
<property name="whiteSpace">nowrap</property>
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="95">
<data id="96">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="97">
<data id="98">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="99">
<data id="100">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="101">
<data id="102">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
<cell id="103">
<data id="104">
<property name="resultSetColumn">rwc</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="105">
<cell id="106"/>
<cell id="107"/>
<cell id="108"/>
<cell id="109"/>
<cell id="110"/>
<cell id="111"/>
</row>
</footer>
</table>
<table id="118">
<property name="masterPage">MP2</property>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
</structure>
</list-property>
<structure>
<property name="operator">gt</property>
<value>30</value>
</structure>
</list-property>
<column id="152"/>
<column id="153"/>
<column id="154"/>
<column id="155"/>
<column id="156"/>
<column id="157"/>
<header>
<row id="119">
<cell id="120">
<label id="121">
<text-property
</label>
</cell>
<cell id="122">
<label id="123">
<text-property
</label>
</cell>
<cell id="124">
<label id="125">
<text-property
</label>
</cell>
<cell id="126">
<label id="127">
<text-property
</label>
</cell>
<cell id="128">
<label id="129">
<text-property
</label>
</cell>
<cell id="130">
<label id="131">
</label>
</cell>
</row>
</header>
<detail>
<row id="132">
<cell id="133">
<data id="134">
<property
</data>
</cell>
<cell id="135">
<data id="136">
<property
</data>
</cell>
<cell id="137">
<data id="138">
<property
</data>
</cell>
<cell id="139">
<data id="140">
<property
</data>
</cell>
<cell id="141">
<data id="142">
<property
</data>
</cell>
<cell id="143">
<data id="144">
</data>
</cell>
</row>
</detail>
<footer>
<row id="145">
<cell id="146"/>
<cell id="147"/>
<cell id="148"/>
<cell id="149"/>
<cell id="150"/>
<cell id="151"/>
</row>
</footer>
</table>
</body>
</report>
On 2/1/2011 4:59 PM, Steve Bliss wrote:
> Jason Weathersby wrote on Tue, 01 February 2011 16:04
>> for a report element set the master page property for the report item.
> I tried that, I set the Page Break / Master Page property for an element
> near the beginning of the report design to my 'second page' masterpage -
> but it forced an immediate page break at that element, instead of
> continuing the flow on page 1.
> Is there a way to select one masterpage for page 1, and a different
> masterpage for pages 2+?
> Steve
Re: Create Report with a Title Page [message #654234 is a reply to message #652998] |
Mon, 14 February 2011 17:17 |
Steve Bliss Messages: 15 Registered: February 2011 |
UPDATE to the UPDATE - The solution I explained above only works when there are hard page breaks (ie, an element has the "break before" or "break after" option set). When the report content is long enough to cause a "soft page break" at the end of page 1, the footer on the second page comes out exactly the same as the page 1 footer.
I went back to using Jason's suggestion, using two different master pages, with two elaborations. First, my report has both group header lines and occasional detail footer lines, with different font sizes and therefore, line heights. Additionally, the detail footers sometimes word-wrap onto multiple lines. So, instead of counting the number lines, I actually had to estimate 'line' heights.
The second elaboration is my report has several report elements following the main detail table, and then 2 additional sections on separate pages with their own detail. For the trailing elements in the first section, I added the total height of the detail section into the report. Then I created an OnCreate script for each element, something like:
if ( totalDetailHeight >= 38 ) { this.getStyle().masterPage = "SecondMasterPage"; }
Finally, the 2 additional report sections were hard-assigned to the "SecondMasterPage", under the Page Break properties section.
FUDForum. Page generated in 0.03859 seconds
