Re: Updating Papyrus [message #651763 is a reply to message #651761] |
Tue, 01 February 2011 13:59 |
First of all, I would advise you not to switch to the 0.8.0 version, which aims the next major version of Eclipse (Indigo).
Current version 0.7.2 should be the most stable version of the tool, as it is based on helios current version of Eclipse platform.
If you really want to have test for Papyrus 0.8.0 M4, the easiest is to download the Eclipse modeling package Indigo M4, and install Papyrus from this package. This should be the easiest way. Note that the discovery UI (Install Modeling Components) has not been updated and still targets Papyrus 0.7.2 version in the Package modeling for Indigo. You have to enter the following adress in the install new software interface: http://download.eclipse.org/modeling/mdt/papyrus/updates/mil estones/0.8/
The tool we are currently using for Papyrus build does not allow us to retrieve and display automatically dependencies as it is done in GMF build system. I should write a small script that retrieves this from the build system, but unfortunately, I have many other things to do currently :/
Rémi
Remi Schnekenburger
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
FUDForum. Page generated in 0.03274 seconds
