Home » Eclipse Projects » Remote Application Platform (RAP) » Tree widget and horizonal scrollbar
icon5.gif  Tree widget and horizonal scrollbar [message #651689] Tue, 01 February 2011 10:04 Go to next message
Opfermann C is currently offline Opfermann CFriend
Member
I'm having some issue with the horizontal scrollbar in RAP.
Indeed, the scrollbar appears but is disabled (grayed).
Has somebody already tried this and faced the same issue ?
Re: Tree widget and horizonal scrollbar [message #651699 is a reply to message #651689] Tue, 01 February 2011 10:12 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
which version of RAP are you using? Since 1.4M4 we replaced the native
browser scrollbars with a custom one. Could you provide a snippet to
demonstrate the issue?
Best,
Ivan
On 2/1/2011 12:04 PM, Opfermann C wrote:
> Regards,
Re: Tree widget and horizonal scrollbar [message #651766 is a reply to message #651699] Tue, 01 February 2011 14:19 Go to previous messageGo to next message
Member
I'm currently in 1.4M3, so, I'll test in M4, and come back is the problem persists.
Re: Tree widget and horizonal scrollbar [message #651975 is a reply to message #651766] Wed, 02 February 2011 10:39 Go to previous messageGo to next message
Member
I tested with the 1.4M4 and it doesn't work.
The scrollbar appears, is enabled, but it takes always the full size of the scrollbar.
How can I attach a file to a forum post to send you a snippet ?
Re: Tree widget and horizonal scrollbar [message #651979 is a reply to message #651975] Wed, 02 February 2011 10:48 Go to previous messageGo to next message
Hi Opfermann,
if you think that this is a bug and works in SWT please file a bugzilla
and attach a snippet there.
Ivan
> of the scrollbar.
Re: Tree widget and horizonal scrollbar [message #652066 is a reply to message #651979] Wed, 02 February 2011 15:03 Go to previous messageGo to next message
Member
I think that this is the same issue =>
https://bugs.eclipse.org/bugs/show_bug.cgi?id=332710
Re: Tree widget and horizonal scrollbar [message #652083 is a reply to message #652066] Wed, 02 February 2011 15:44 Go to previous message
In this case it's already fixed into upcoming 1.4M5 milestone :-)
Previous Topic:Canvas drawing performance optimization
Next Topic:Problem Deploy WAR
Current Time: Wed Dec 01 04:40:03 GMT 2021
Powered by FUDForum. Page generated in 0.01665 seconds
