Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3] Multiple metamodels
[Acceleo 3] Multiple metamodels [message #651496] Mon, 31 January 2011 12:45 Go to next message
Supernova S. is currently offline Supernova S.Friend
Is it possible in the new version of Acceleo (3.xx) to use more than one metamodel in a generation template/module? It would be great if you can provide some information on how to do this.
Mehrdad
[Updated on: Mon, 31 January 2011 12:49]
Report message to a moderator
Re: [Acceleo 3] Multiple metamodels [message #651536 is a reply to message #651496] Mon, 31 January 2011 15:26 Go to previous messageGo to next message
Stephane Begaudeau is currently offline Stephane BegaudeauFriend
[module myModule('myMetamodel1', 'myMetamodel2', 'myMetamodel3')/]
Stephane Begaudeau, Obeo
Re: [Acceleo 3] Multiple metamodels [message #652019 is a reply to message #651536] Wed, 02 February 2011 13:13 Go to previous messageGo to next message
Thanks!
was this feature to use multiple metamodels also possible in acceleo 2.x?
Re: [Acceleo 3] Multiple metamodels [message #652059 is a reply to message #652019] Wed, 02 February 2011 14:46 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent GoubetFriend
--------------030008010906020608050507
Hi Mehrdad,
And nope, this wasn't possible with the Acceleo 2.* stream and has been
added for 3.*.
Laurent Goubet
Obeo
On 02/02/2011 14:13, Mehrdad Saadatmand wrote:
> Thanks!
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------030008010906020608050507--
Re: [Acceleo 3] Multiple metamodels [message #931864 is a reply to message #652059] Wed, 03 October 2012 15:42 Go to previous messageGo to next message
Frederik Gailly is currently offline Frederik GaillyFriend
I have a related problem. My mtl file recognizes my two metamodels but after running the file I do not get the correct result because it seems that the generator can only access the instantiation of my first metamodel and not the instantiation of my second metamodel.
Put differently: Is it possible two add 2 models as input files which contain references to each other.
Frederik
Re: [Acceleo 3] Multiple metamodels [message #938858 is a reply to message #931864] Wed, 10 October 2012 08:10 Go to previous messageGo to next message
If you want to use multiple models in your generator, you should start with one of the models and then navigate to elements of the second one in the generator. If the second one is not loaded, you can use the code in the comment in the method "doGenerate" (//org.eclipse.emf.ecore.util.EcoreUtil.resolveAll(model)).
Twitter: @sbegaudeau & @acceleo
Google+: stephane.begaudeau & acceleo
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
[Updated on: Wed, 10 October 2012 08:10]
Re: [Acceleo 3] Multiple metamodels [message #1737068 is a reply to message #938858] Tue, 05 July 2016 13:01 Go to previous message
[edited out : wrong thread]
[Updated on: Tue, 05 July 2016 13:13]
Previous Topic:[Acceleo] PackageNotFoundException
Next Topic:Two input models in Acceleo
Current Time: Sun Aug 25 04:30:14 GMT 2019
Powered by FUDForum. Page generated in 0.02115 seconds
