WSDL2 is not generated for webservices [message #651310] |
Fri, 28 January 2011 21:28 |
Alla Messages: 5 Registered: September 2010 |
I was trying to create web service bootom up.
Here it is my environment:
Tomcat 6.029, jdk 6.023, eclipse 3.6.1, axis2 -1.5.4
I was following the tutorial at I was trying to create web service bottom up.
I was following the tutorial at http://www.vogella.de/articles/Webservice/article.html#intro duction_wtp, but cold not successfully complete it.
the problem is that the wizard is omitting step for wsdl creation, and creates only services.xml
If I change the web service runtime environment to AXIS ( instead of AXIS2), it will create the wsdl 1, but cannot install it, probably because I do not have AXIS runtime environment , I have AXIS 2 instead. Then if I retry to rebuild it again with AXIS2 for runtime, it will deploy the webservice into runtime environment, but it won't work, because the system is complaining about not finding endpoint, while it is defined as port. I assume that there is a mismatch between the version of wsdl and the runtime environment.
I was trying to generate wsdl using annotation and without annotation, but I am getting the same result.
I would appreciate if you let me know how to get wsdl2 to be generated.
thanks
FUDForum. Page generated in 0.03643 seconds
