Re: Attempting to change GroupingInterval in a script [message #651567 is a reply to message #651305] |
Mon, 31 January 2011 16:24 |
Mike
Where are you putting this script? You could always name the chart in
the general properties of the chart and do it in the beforeFactory
script of the report like:
var chart1 = this.getReportElement( "MyChart" )
catg = chart1.getCategory().getGrouping();
catg.setEnabled( true );
catg.setGroupInterval(1);
catg.setGroupType("DateTime");
catg.setGroupUnit("Months");
See attached example.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="comments">Copyright (c) 2007 <<Your Company
Name here>></property>
<property name="createdBy">Eclipse BIRT Designer Version
2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<property name="units">in</property>
<method name="beforeFactory"><![CDATA[importPackage(
Packages.org.eclipse.birt.chart.model.data.impl );
importPackage( Packages.org.eclipse.birt.chart.model.attribute.impl );
importPackage( Packages.org.eclipse.birt.chart.model.attribute );
]]></method>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">auto layout</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="7">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">ORDERDATE</property>
<text-property
name="displayName">ORDERDATE</text-property>
</structure>
<structure>
<property name="columnName">REQUIREDDATE</property>
<text-property
name="displayName">REQUIREDDATE</text-property>
</structure>
<structure>
<property name="columnName">SHIPPEDDATE</property>
<text-property
name="displayName">SHIPPEDDATE</text-property>
</structure>
<structure>
<property name="columnName">STATUS</property>
<text-property
name="displayName">STATUS</text-property>
</structure>
<structure>
<property name="columnName">COMMENTS</property>
<text-property
name="displayName">COMMENTS</text-property>
</structure>
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<text-property
name="displayName">CUSTOMERNUMBER</text-property>
</structure>
</list-property>
<list-property name="filter">
<structure>
<property name="operator">lt</property>
<expression name="expr">row["ORDERDATE"]</expression>
<simple-property-list name="value1">
<value>"03/01/2003"</value>
</simple-property-list>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">ORDERDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">STATUS</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">COMMENTS</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">CUSTOMERNUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">STATUS</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">COMMENTS</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orders]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERDATE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>ORDERDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERDATE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>REQUIREDDATE</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>REQUIREDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>REQUIREDDATE</design:label>
<design:attributes>
<design:name>SHIPPEDDATE</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>SHIPPEDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SHIPPEDDATE</design:label>
<design:attributes>
<design:name>STATUS</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>STATUS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATUS</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>COMMENTS</design:name>
<design:position>6</design:position>
<design:precision>32700</design:precision>
<design:uiHints>
<design:displayName>COMMENTS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COMMENTS</design:label>
<design:displaySize>32700</design:displaySize>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>7</design:position>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">1in</property>
<property name="leftMargin">1.25in</property>
<property name="bottomMargin">1in</property>
<property name="rightMargin">1.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<extended-item extensionName="Chart" name="MyChart" id="8">
<xml-property
name="xmlRepresentation"><![CDATA[<model:ChartWithAxes
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:data="http://www.birt.eclipse.org/ChartModelData"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Type>Bar Chart</Type>
<SubType>Side-by-side</SubType>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Visible>true</Visible>
<Label>
<Caption>
<Value>Bar Chart Title</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Right</Position>
<ItemType>Series</ItemType>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Above</TitlePosition>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>430.50000000240004</Width>
<Height>273.0000000024</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
</Block>
<Dimension>Two_Dimensional_With_Depth</Dimension>
<Script>function beforeGeneration(chart, icsc)
icsc.getLogger().log(icsc.getLogger().WARNING, "Test Log Message
from the Chart Engine");
//currently the chart model only supports one base axis
xAxis = chart.getBaseAxes()[0];
yAxis = chart.getOrthogonalAxes( xAxis, true)[0];
yAxisNumber2 = chart.getOrthogonalAxes( xAxis, true)[1];
if ( xAxis.getType() == AxisType.DATE_TIME_LITERAL)
xAxis.setFormatSpecifier(
JavaDateFormatSpecifierImpl.create("MM-dd-yyyy& quot;) );
* Called after generation of chart model to GeneratedChartState.
* @param gcs
* GeneratedChartState
* @param icsc
* IChartScriptContext
function afterGeneration( gcs, icsc )
function beforeDrawAxisLabel( axis, label, icsc )
importPackage(
importPackage(
if( axis.getTitle( ).getCaption( ).getValue( ) ==
"myYaxisTitle" )
label.getCaption( ).setColor(
ColorDefinitionImpl.BLUE( ) );
if ( axis.getType( ) == AxisType.DATE_TIME_LITERAL )
ColorDefinitionImpl.RED( ) );
* Called after the chart is rendered.
* @param gcs
* @param icsc
function afterRendering( gcs, icsc )
* Called before drawing the legend item.
* @param lerh
* LegendEntryRenderingHints
* @param bounds
* Bounds
* @param icsc
* @since Version 2.2.0
function beforeDrawLegendItem( lerh, bounds, icsc )
</Script>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>01/05/2000,02/01/2000,04/12/2000</DataSetRepresentation >
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>5,4,12</DataSetRepresentation>
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
<AncillarySampleData>
<DataSetRepresentation>Series 1</DataSetRepresentation>
</AncillarySampleData>
</SampleData>
<Interactivity/>
<EmptyMessage>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</EmptyMessage>
<Axes>
<Type>DateTime</Type>
<Title>
<Caption>
<Value>X-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>myYaxisTitle</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>90.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series xsi:type="type:BarSeries">
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["CUSTOMERNUMBER"]</Definition >
</DataDefinition>
<SeriesIdentifier></SeriesIdentifier>
<DataPoint>
<Components>
<Type>Orthogonal_Value</Type>
</Components>
<Separator>, </Separator>
</DataPoint>
<LabelPosition>Outside</LabelPosition>
<Stacked>false</Stacked>
<Riser>Rectangle</Riser>
</Series>
<Grouping>
<Enabled>false</Enabled>
<GroupingInterval>2.0</GroupingInterval>
<GroupType>Text</GroupType>
<AggregateExpression>Sum</AggregateExpression>
</Grouping>
<Sorting>Ascending</Sorting>
</SeriesDefinitions>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Left</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickStyle>Across</TickStyle>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
<MinorGridsPerUnit>5</MinorGridsPerUnit>
</Scale>
<Origin>
<Type>Min</Type>
<Value xsi:type="data:NumberDataElement">
<Value>0.0</Value>
</Value>
</Origin>
<PrimaryAxis>true</PrimaryAxis>
<Percent>false</Percent>
</AssociatedAxes>
<AncillaryAxes>
<Type>Text</Type>
<Title>
<Caption>
<Value>myZaxis</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
Re: Attempting to change GroupingInterval in a script [message #651581 is a reply to message #651575] |
Mon, 31 January 2011 17:09 |
Mike,
If its in the beforeFactory just set it to
params["YourReportParameter"].value
Jason
On 1/31/2011 12:04 PM, Mike Wulkan wrote:
> Thank you very much for your prompt response. This code works; must
> have been where I hooked it in.
> One more thing though; how do I change the interval value from a hard
> coded (eg., "1") to reference a report parameter?
> Mike
FUDForum. Page generated in 0.03803 seconds
