[Acceleo 3] - Expression in <init> clause of template [message #650849] |
Wed, 26 January 2011 20:06  |
I want to use the <init> clause of a template to initialize some variables based on the additional parameters.
[template public ddl(item : Item, isAuditTable : Boolean, suffix : String)
tableName : String = item.name + 'xxx';
fullTableName : String = item.name + (isAuditTable ? '_AUDIT' : '_NORMAL');
I get a compilation error 'unexpected tokens' on the use of (isAuditTable ? '...' : '...)
Is there a way to use a 'conditional expression' in the init clause?
Luc
Re: [Acceleo 3] - Expression in <init> clause of template [message #650922 is a reply to message #650849] |
Thu, 27 January 2011 07:55   |
--------------010403080802030400070306
Hi Luc,
There is no ternary operator in OCL. You have to use a regular "if else
endif" :
fullTableName : String = item.name + (if (isAuditTable) then '_AUDIT'
else '_NORMAL' endif);
Laurent Goubet
Obeo
On 26/01/2011 21:06, Luc De Graef wrote:
> Hello,
> Regards
> Luc
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010403080802030400070306--
Re: [Acceleo 3] - Expression in <init> clause of template [message #650934 is a reply to message #650925] |
Thu, 27 January 2011 08:26  |
--------------030502080006060104070101
Yup, Acceleo is an implementation of the MOF Model to Text standard ...
but this itself heavily depends on OCL. Most of the "expressions" you
will use in Acceleo are in fact OCL expressions (augmented with our own
standard library operations).
We provide in the documentation (Help > Help Contents > Acceleo Model to
Text) a reference guide of the standard OCL operations. Though this
guide still sports some typos, you can use it in order to find your way
around OCL.
Laurent Goubet
Obeo
On 27/01/2011 09:19, Luc De Graef wrote:
> I had looked into the MOF Model to Text Specification Guide, but I now
> realize I need to review the OCL specifications also...
> Regards,
> Luc
--------------030502080006060104070101--
FUDForum. Page generated in 0.04363 seconds
