Home » Eclipse Projects » EGit / JGit » Change GIT repository location with SHARE?
Change GIT repository location with SHARE? [message #650431] Mon, 24 January 2011 20:24 Go to next message
Garry  is currently offline Garry Friend
I can't seem to change the git repository location when I SHARE my project. It always specifies my "~/.git" folder even though I have initialized a second git repository in a different location. There is an option on the share page to create a repository but it's always grayed out. How can I share my project to an arbitrary git repository on my local file system.
Environment: MacOS 10.5
Thanks, Garry
Re: Change GIT repository location with SHARE? [message #650654 is a reply to message #650431] Tue, 25 January 2011 20:57 Go to previous message
Create the git repository folder inside your project folder and you'll be able to see it in Eclipse. This approach makes sense with Git as you typically create a lot of repositories, for instance, one for each project.
Garry
Previous Topic:Error commiting
Next Topic:Resetting/Unstaging Files Does Not Seem To Work
Current Time: Fri Dec 02 07:37:10 GMT 2022
Powered by FUDForum. Page generated in 0.02417 seconds
