Home » Archived » Maven Integration (M2E) » problem using Checkout as Maven project from SCM Window(SCM URL pull down menu has no options)
problem using Checkout as Maven project from SCM Window [message #650313] Mon, 24 January 2011 11:31 Go to next message
Entfred Smith is currently offline Entfred SmithFriend
I am trying to checkout a Maven project from SCM using
Eclipse (i.e. get latest jpetstore). There is a prompt to
select SCM type and URL. I put in the URL of jpetstore
https://src.springframework.org/svn/spring-samples/jpetstore /trunk/org.springframework.samples.jpetstore/
but the SCM URL pull down menu has no options - every
option is blank.
Does anybody know how to sue this Checkout as Maven project
from SCM window in Eclipse to check out the above
jpetstore sample Spring app?
Thanks!
--- Entfred
Re: problem using Checkout as Maven project from SCM Window [message #651182 is a reply to message #650313] Fri, 28 January 2011 09:25 Go to previous messageGo to next message
Giorgio Gamberini is currently offline Giorgio GamberiniFriend
I have exactly the same problem, Helios SR1, Maven integration 0.12.1.
Someone here knows how to solve this, please?
(BTW, trying to check out Fedora Commons from Git repo)
Giorgio
Re: problem using Checkout as Maven project from SCM Window [message #651262 is a reply to message #650313] Fri, 28 January 2011 16:11 Go to previous messageGo to next message
Jordan Hein is currently offline Jordan HeinFriend
I'm not much help but I believe I remember there is an additional plugin that enables SCM support with m2eclipse.
I think this may help: http://maven.40175.n5.nabble.com/m2Eclipse-td125234.html
Re: problem using Checkout as Maven project from SCM Window [message #651270 is a reply to message #651262] Fri, 28 January 2011 16:23 Go to previous messageGo to next message
Thanks Jordan, will check that link out ASAP. Smile
Giorgio
Re: problem using Checkout as Maven project from SCM Window [message #694001 is a reply to message #650313] Thu, 07 July 2011 15:55 Go to previous message
Vibin is currently offline VibinFriend
Go to install software in eclipse
Add and install the url
m2eclipse.sonatype.org/sites/m2e-extras
restart the Eclipse. You will be able to see svn as the option while you select the check out option from maven.
Previous Topic:Prevent downloading repository index updates on startup
Next Topic:incorrect .classpath if project has wsimport goal
Current Time: Sun Jan 17 16:59:29 GMT 2021
Powered by FUDForum. Page generated in 0.02188 seconds
