Home » Eclipse Projects » Plugin Development Environment (PDE) » Integration of Findbugs into PDE build
Integration of Findbugs into PDE build [message #650084] Fri, 21 January 2011 16:46 Go to next message
Aurélien Pupier is currently offline Aurélien PupierFriend
I would like to integrate Findbugs into my PDE build.
I follow this blogpost http://spektom.blogspot.com/2010/11/run-findbugs-from-your-e clipse-rcp.html with the comment of Andrew Niefer.
So,
I create my customBuildCallbacks.xml with in post.compile.@dot:
<target name="post.compile.@dot">
		<!-- Run FindBugs: -->
		<findbugs
			home="${env.FINDBUGS_HOME}"
			output="xml"
			failOnError="false"
			jvmargs="-server -Xss1m -Xms512m -Xmx1024m"
			outputFile="findbugs-application.xml"
			debug="true"
			effort="min">
			<!--auxClasspath path="${library.jar.classpath}" /-->
			<class location="${target.foler}" />
			<sourcePath path="${basedir}" />
		</findbugs>
	</target>
and defining findbugs task:
<taskdef name="findbugs" classname="edu.umd.cs.findbugs.anttask.FindBugsTask">
	<classpath>
		<path>[CODE][/CODE]
			<fileset
				dir="${env.FINDBUGS_HOME}/lib"
				includes="*.jar">
			</fileset>
		</path>
	</classpath>
</taskdef>
I'm trying to use the UI to generate the plugin via File->export->Plug-in Development->Deployable plug-ins and fragments
choose a directory destination and then clisk Finish.
It begins great but finally, the export failed(customBuildCallbacks.xml:98: Execution of findbugs failed.) with this stacktrace:
F:\ws\3.6RC2\.metadata\.plugins\org.eclipse.pde.core\temp\org.eclipse.pde.container.feature\compile.org.eclipse.pde.container.feature.xml:4: The following error occurred while executing this line:
F:\ws\3.6RC2\plugins\org.bonitasoft.studio.application\build.xml:529: The following error occurred while executing this line:
F:\ws\3.6RC2\plugins\org.bonitasoft.studio.application\build.xml:493: The following error occurred while executing this line:
F:\ws\3.6RC2\plugins\org.bonitasoft.studio.application\customBuildCallbacks.xml:98: Execution of findbugs failed.
	at org.apache.tools.ant.ProjectHelper.addLocationToBuildException(ProjectHelper.java:508)
	at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:418)
	at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:288)
	at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
	at org.apache.tools.ant.Task.perform(Task.java:348)
	at org.apache.tools.ant.Target.execute(Target.java:357)
	at org.apache.tools.ant.Target.performTasks(Target.java:385)
	at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1337)
	at org.apache.tools.ant.Project.executeTarget(Project.java:1306)
	at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
	at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.executeTargets(EclipseDefaultExecutor.java:32)
	at org.apache.tools.ant.Project.executeTargets(Project.java:1189)
	at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:662)
	at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:495)
	at org.eclipse.ant.core.AntRunner.run(AntRunner.java:378)
	at org.eclipse.pde.internal.core.exports.FeatureExportOperation.runScript(FeatureExportOperation.java:424)
	at org.eclipse.pde.internal.core.exports.FeatureExportOperation.doExport(FeatureExportOperation.java:262)
	at org.eclipse.pde.internal.core.exports.FeatureBasedExportOperation.run(FeatureBasedExportOperation.java:50)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: F:\ws\3.6RC2\plugins\org.bonitasoft.studio.application\build.xml:529: The following error occurred while executing this line:
	at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget.java:105)
	at sun.reflect.GeneratedMethodAccessor114.invoke(Unknown Source)
	at org.apache.tools.ant.helper.SingleCheckExecutor.executeTargets(SingleCheckExecutor.java:38)
	at org.eclipse.ant.internal.core.ant.EclipseSingleCheckExecutor.executeTargets(EclipseSingleCheckExecutor.java:30)
	at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:416)
	... 25 more
Caused by: F:\ws\3.6RC2\plugins\org.bonitasoft.studio.application\build.xml:493: The following error occurred while executing this line:
	at org.apache.tools.ant.taskdefs.SubAnt.execute(SubAnt.java:289)
	at org.apache.tools.ant.taskdefs.SubAnt.execute(SubAnt.java:208)
	... 39 more
Caused by: F:\ws\3.6RC2\plugins\org.bonitasoft.studio.application\customBuildCallbacks.xml:98: Execution of findbugs failed.
	at edu.umd.cs.findbugs.anttask.FindBugsTask.afterExecuteJavaProcess(FindBugsTask.java:551)
	at edu.umd.cs.findbugs.anttask.AbstractFindBugsTask.execFindbugs(AbstractFindBugsTask.java:369)
	at edu.umd.cs.findbugs.anttask.AbstractFindBugsTask.execute(AbstractFindBugsTask.java:216)
	... 54 more
--- Nested Exception ---
	... 39 more
	... 54 more
	... 54 more
I don't find any other information.
I tried to launch ant task inside .metadata\.plugins\org.eclipse.pde.core\temp\org.eclipse.pde .container.feature\compile.org.eclipse.pde.container.feature .xml in order to have more trace but it failed.
Launching findbugs from a simple build.xml file pointing to myProject/src and myProject/bin works pretty fine:
 [findbugs] Warnings generated: 41
 [findbugs] Missing classes: 396
 [findbugs] Calculating exit code...
 [findbugs] Setting 'missing class' flag (2)
 [findbugs] Setting 'bugs found' flag (1)
 [findbugs] Exit code set to: 3
 [findbugs] Java Result: 3
 [findbugs] Classes needed for analysis were missing
 [findbugs] Output saved to F:\findbugs-application.xml
BUILD SUCCESSFUL
Total time: 1 minute 49 seconds
Anybody has an idea on how make it works, how debug it?
Thanks by advance for any help
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
Re: Integration of Findbugs into PDE build [message #650098 is a reply to message #650084] Fri, 21 January 2011 17:49 Go to previous messageGo to next message
Martin Skorsky is currently offline Martin SkorskyFriend
My PDE build works with findbugs.
I'm using
<taskdef name="findbugs" classname="edu.umd.cs.findbugs.anttask.FindBugsTask" classpath="${findbugs.home}/lib/findbugs.jar" />
Re: Integration of Findbugs into PDE build [message #650100 is a reply to message #650098] Fri, 21 January 2011 17:55 Go to previous messageGo to next message
ok, and where are you searching the .class files and src files?
Is your project Open Source in order that I can take a look on the build?
Re: Integration of Findbugs into PDE build [message #650302 is a reply to message #650100] Mon, 24 January 2011 10:21 Go to previous messageGo to next message
It is not Open Source.
The FindBugs call is done in the customCallbacks.xml, because there I have the classpath of the bundle.
I use:
<!-- Steps to do during the compilation target <name>, after the compile -->
<!-- but before jaring. Substitute "name" with the name of the compilation-->
<!-- target, eg @dot -->
<!-- Available parameters : -->
<!-- source.foldern : n = 1 ... N, the source folders -->
<!-- target.folder : where the results of the compilation go -->
<!-- <name>.classpath : name = name of the compilation target. A -->
<!-- reference to the classpath structure. -->
<pathconvert property="path.property" refid="@dot.classpath">
<map from="${basedir}_${bundleVersion}" to="${basedir}" />
</pathconvert>
<path id="path1" location="${path.property}">
</path>
<call-findbugs project="${ant.project.name}" src="${source.folder1}" jar="@dot" classpath="path1" />
</target>
The pathconvert removes some duplicate entries from the classpath.
Re: Integration of Findbugs into PDE build [message #650305 is a reply to message #650084] Mon, 24 January 2011 10:34 Go to previous messageGo to next message
Thanks for your help.
But I can't make it works.
What is call-findbugs task?
I'm using findbugs task trying to follow what you have done:
		</pathconvert>
		</path>
		<findbugs
			home="C:\Users\aPupier\Downloads\findbugs-1.3.9\findbugs-1.3.9"
			output="xml"
			failOnError="false"
			jvmargs="-Xms512m -Xmx1024m"
			debug="true"
			effort="min">
			<auxClasspath path="${path1}" />
			<class location="@dot" />
			<sourcePath path="${source.folder1}" />
		</findbugs>
	</target>
But I have the same issue than previsouly.
Re: Integration of Findbugs into PDE build [message #650325 is a reply to message #650305] Mon, 24 January 2011 12:14 Go to previous messageGo to next message
The findbugs task looks OK.
The <auxClasspath ... should be
<auxClasspath refid=path1 />
The <debug="true" / should be "false". For "true" we get lots of FindBugs internals.
Re: Integration of Findbugs into PDE build [message #650340 is a reply to message #650084] Mon, 24 January 2011 12:56 Go to previous messageGo to next message
Thank you again.
you're right refid seems better.
I tried to put debug to false too.
but I've got still the same issue Sad
Which version of findbugs are using? (mine 1.3.9)
on your side, is it also working via UI? (right-click on prject->export...->deployable plug-ins and fragment-> Finish
Re: Integration of Findbugs into PDE build [message #651083 is a reply to message #650340] Thu, 27 January 2011 17:14 Go to previous message
I'm using findbugs 1.3.9
I cannot start this build as a feature / plug-in export because it involves custom steps which are available only on special servers which do a headless build.
What is your error message?
Previous Topic:[PDE-Build] Build Groovy files
Next Topic:Instatiate an inner class usign createExecutableExtension ()
Current Time: Sat Sep 18 08:22:52 GMT 2021
Powered by FUDForum. Page generated in 0.01941 seconds
