Home » Eclipse Projects » Remote Application Platform (RAP) » Table V_SCROLL Issue(Table rows are not scrolled into view when table expanded)
Table V_SCROLL Issue [message #650049] Fri, 21 January 2011 14:37 Go to next message
Tiber Sept is currently offline Tiber SeptFriend
Member
Hello RAP community,
I have encountered an issue with the table widget regarding vertical scrolling. I am working
against RAP 1.4 M4. The following does not work for me:
  1. Enforce appearance of vertical scroll bar
  2. Scroll down
  3. Increase table height
As a result the top table rows that were scrolled out of view are not scrolled back into view
as is the case in SWT/RCP.
Additionally, I have encountered a similar issue with horizontal scolling. If the horizontal scrollbar
is moved to the the middle or the right end and the table width is increased, the rows are positioned
properly, but the columns seem to stay in their original position.
Is this a known issue ? Do you get the same behavior ? Is that behavior expected ?
tibersept
Re: Table V_SCROLL Issue [message #650079 is a reply to message #650049] Fri, 21 January 2011 15:52 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi tibersept,
today we fixed a similar problem with Tree (actually it was an issue
with the new Scrollbar). There is a possibility, the fix in the
Scrollbar to fix this issue too. To double check the problem, could you
open a bug with a snippet to reproduce it?
Ivan
> scrolling. I am working against RAP 1.4 M4. The following does not
> work for me:
> Scroll down
> scrolled back into view as is the case in SWT/RCP.
> scolling. If the horizontal scrollbar is moved to the the middle or
> positioned properly, but the columns seem to stay in their original
> position.
> behavior expected ?
> tibersept
Re: Table V_SCROLL Issue [message #650080 is a reply to message #650049] Fri, 21 January 2011 16:06 Go to previous messageGo to next message
Just checked it... I think that both issues are fixed today in CVS HEAD
with bug:
334103: [Tree] Sibling items are not visible after collapsing tree
https://bugs.eclipse.org/bugs/show_bug.cgi?id=334103
Best,
Ivan
> work for me:
> Scroll down
> position.
> behavior expected ?
> tibersept
Re: Table V_SCROLL Issue [message #650127 is a reply to message #650080] Fri, 21 January 2011 20:12 Go to previous message
Member
Hello Ivan,
I confirm that the issue has been fixed in CVS HEAD
tibersept
Previous Topic:Java Heap Space and RAP
Next Topic:Title Bar Menu's disappearing in 1.4M4 on Firefox
Current Time: Wed Dec 08 04:50:24 GMT 2021
Powered by FUDForum. Page generated in 0.01943 seconds
