Re: Table V_SCROLL Issue [message #650079 is a reply to message #650049] |
Fri, 21 January 2011 15:52 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi tibersept,
today we fixed a similar problem with Tree (actually it was an issue
with the new Scrollbar). There is a possibility, the fix in the
Scrollbar to fix this issue too. To double check the problem, could you
open a bug with a snippet to reproduce it?
Ivan
On 1/21/2011 4:37 PM, tibersept wrote:
> Hello RAP community,
> I have encountered an issue with the table widget regarding vertical
> scrolling. I am working against RAP 1.4 M4. The following does not
> work for me:
> Enforce appearance of vertical scroll bar
> Scroll down
> Increase table height
> As a result the top table rows that were scrolled out of view are not
> scrolled back into view as is the case in SWT/RCP.
> Additionally, I have encountered a similar issue with horizontal
> scolling. If the horizontal scrollbar is moved to the the middle or
> the right end and the table width is increased, the rows are
> positioned properly, but the columns seem to stay in their original
> position.
> Is this a known issue ? Do you get the same behavior ? Is that
> behavior expected ?
> tibersept
FUDForum. Page generated in 0.03595 seconds
