[Acceleo] Class inheritance and recursivity [message #649684] |
Thu, 20 January 2011 10:03 |
I'm trying to make an Acceleo template but I'm stuck at one point:
I'm not able to know which are the entire superclasses stack of the Class I'm generating.
Let's take an example:
Human<-User<-Player.
I wanted to have a set containing [Human, User] from the Player class, the same for a nineth degrees inheritance.
I don't see how can I do that without variable declaration.
Thanks in advance, Tcharl
Re: [Acceleo] Class inheritance and recursivity [message #649709 is a reply to message #649684] |
Thu, 20 January 2011 12:08 |
Hi Charlie,
I'm not sure that I understood your problem, I don't get this part: "I wanted to have a set containing [Human, User] from the Player class, the same for a nineth degrees inheritance."
Could you show us a small template with comments explaining what you would expect from the generation.
Thanks.
Stephane Begaudeau, Obeo
Re: [Acceleo] Class inheritance and recursivity [message #649716 is a reply to message #649709] |
Thu, 20 January 2011 12:19 |
I'll try so,
Let's have a Human (abstract) with a name and a surname.
Let's have a User (abstract) that extends Human with an email & pwd.
Let's have a Player with his poker stack.
I'm trying to generate a flex datagrid containing columns name/surname/email/pwd/stack.
[template public AllDataFromAConcreteClass(c : Class)]
[if(not(c.isAbstract()]
<mx:DataGrid x="27" y="26" dataProvider="{model.all[c.name/]}" >
<mx:columns>
[comment]
this class attribute
[/comment]
[for (p: Property |c.attribute)]
<mx:DataGridColumn headerText="[p.name/]"
dataField="[p.name/]"/>
[/for]
[for(superC : Class | c.getAllAbstractSuperclassStackThatIDontKnowHowToDo())]
[for (p: Property |superC.attribute)]
[/for]
[/for]
</mx:columns>
</mx:DataGrid>
[/if]
[/template]
Something like c.inheritedMember but for Class elements
[Updated on: Thu, 20 January 2011 13:20] Report message to a moderator
Re: [Acceleo] Class inheritance and recursivity [message #649734 is a reply to message #649716] |
Thu, 20 January 2011 13:16 |
--------------050409050705070005000705
Hi Charlie,
You'll have to know how to go up in your class hierarchy, and do this
either :
- Through an OCL "iterate
- recursively through Acceleo
- Through a Java Service
For example, with recursive queries (and assuming you can retrieve the
super classes through "eSuperTypes") :
[query public getSuperClasses(c : EClass) : Sequence(EClass) = if
c.eSuperTypes->size() = 0 then c.eSuperTypes else
c.eSuperTypes->asSequence()->union(c.eSuperTypes.getSuperClasses()- >flatten())
endif/]
Laurent Goubet
Obeo
On 20/01/2011 13:19, Charlie Mordant wrote:
> I'll try so,
> <mx:columns>
> [/comment]
> [/for]
> [/for]
> [/for]
> </mx:columns>
> </mx:DataGrid>
> [/if]
> [/template]
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------050409050705070005000705--
Re: [Acceleo] Class inheritance and recursivity [message #649745 is a reply to message #649684] |
Thu, 20 January 2011 14:10 |
Thanks Laurent,
I'm such a brainless programmer, recursivity is very easy and I could have guessed it without help.
Here is the acceleo version of the query:
[query public findSuperClassStack(c : Class) : Set(Class) =
if(c.superClass->size() = 0) then c.superClass else c.superClass->asSet()->union(c.superClass.findSuperClassStack()->flatten()->asSet()) endif /]
regards, Charlie
FUDForum. Page generated in 0.15189 seconds
