Re: Saving birt output report on server side [message #649841 is a reply to message #649680] |
Thu, 20 January 2011 17:24 |
You can create either a run task or render task in the after render
event handler to do what you want. You could enter a script like this
to do just a render (note example is in JavaScript but could be done in
Java).
rptdoc =
reportContext.getHttpServletRequest().getAttribute("attributeBean ").getReportDocumentName();
importPackage(Packages.org.eclipse.birt.report.engine.api);
var re = reportContext.getReportRunnable().getReportEngine();
var mdocument = re.openReportDocument(rptdoc);
var options = new PDFRenderOption();
options.setOutputFormat("pdf");
options.setOutputFileName("c:/test/mytest.pdf");
var ntask = re.createRenderTask(mdocument);
ntask.setRenderOption(options);
ntask.render();
ntask.close();
This code has no error checking in it. You also may want to put a check
in to see if you are in the designer and not run the code if you are.
reportContext.getHttpServletRequest().getAttribute("attributeBean ").isDesigner();
Here is an example of doing a run and render task:
var des = re.openReportDesign("c:/xfer/burstdetail.rptdesign");
var ntask = re.createRunAndRenderTask(des);
ntask.setParameterValue("CustomerNumber",
this.getRowData().getColumnValue(0).toString() );
var outputfile = "c:/temp/test" + this.getRowData().getColumnValue(0) +
".pdf";
options.setOutputFileName(outputfile);
ntask.run();
ntask.close();
Jason
On 1/20/2011 4:55 AM, JIE wrote:
> Hi all,
> I'm using birt 2.3.2 to generate PDF report in the Java web application.
> I could view the the output PDF in the firefox now, by clicking a button
> which will forward the request to a JSP page, in which the 'birt:viewer'
> object is defined.
> But I also want to save the PDF into the disk of server side.
> I'm thinking of writing a Java class extending ReportEventAdapter(Using
> afterRender event) and binding it with .rptdesign. But it seems no way
> to get content of report in java class...
> Does anybody know how to do that? Or another solution to save the PDF?
> Any information will be appreciated.
> Thanks in advance!
Re: Saving birt output report on server side [message #650093 is a reply to message #649979] |
Fri, 21 January 2011 16:55 |
Try adding
mdocument.close();
after you close the task.
Jason
On 1/21/2011 4:45 AM, JIE wrote:
> I've tried the Javascript and it generated the pdf in the disk.
> But the pdf cannot be opened (The file is already open or in use by
> another application.)
> Only when the request is changed(I click somewhere else in the
> application) or shut down the server, can it open.
> Do you know why?
> Jason Weathersby wrote on Thu, 20 January 2011 12:24
>> in Java).
>> rptdoc =
>> ntask.render();
>> ntask.close();
>> check in to see if you are in the designer and not run the code if you
>> are.
>> ").isDesigner();
Re: Saving birt output report on server side [message #650390 is a reply to message #650260] |
Mon, 24 January 2011 17:13 |
Try this (again with no error checking):
mmap =
reportContext.getHttpServletRequest().getAttribute("attributeBean ").getModuleOptions();
rptdoc =
importPackage(Packages.java.io)
var mdocument = re.openReportDocument(null,rptdoc, mmap);
baos = new ByteArrayOutputStream();
options.setOutputStream(baos);
ntask.render();
ntask.close();
mdocument.close();
fout = new FileOutputStream("c:/test/myreport.pdf");
fout.write(baos.toByteArray());
fout.flush()
fout.close();
Jason
On 1/23/2011 9:26 PM, JIE wrote:
> Still not working...
Re: Saving birt output report on server side [message #698008 is a reply to message #696831] |
Mon, 18 July 2011 15:16 |
If you are using event scripting to do this look at the attached example
which does a second render in the beforeRendering event.
Jason
On 7/14/2011 6:42 PM, Magg wrote:
> Hi JIE and Jason. I need to implement this approach in my birt reports.
> JIE, do you solved the problem with the generated pdf: "The file is
> already open or in use by another application"? And what other improves
> do you maked to the code? Thanks for your tips and code, I´m novice with
> birt and don´t know how to begin, but your comments are very helpful.
Re: Saving birt output report on server side [message #717940 is a reply to message #717920] |
Mon, 22 August 2011 18:30 |
BIRT does not have any script functions that specifically write back to
a database, but you could always write your own class that inserts into
a db and call it from BIRT event handlers.
Jason
On 8/22/2011 1:47 PM, Magg wrote:
> Hello. One more time I need your valuable help. I can already generate
> my pdf´s, and make the folders if not exists, and personalize the name
> of the pdf with custom params. But also need to register the name of the
> resultant document in my DB. I have been looking for tips in the forum,
> but no entry talk about execute sql in a beforeRender script, or any
> other event. Do you know any link in the forum where discusses about
> that?? Sorry for my very bad english. Thanks in advance.
Re: Saving birt output report on server side [message #1060483 is a reply to message #698008] |
Sat, 25 May 2013 07:27 |
Shashank kumar Messages: 3 Registered: May 2013 |
This is working in birt 3.7.1 but not in 2.3.2 .In 2.3.2 give exception
given below..
org.eclipse.birt.report.engine.api.EngineException: Unhandled exception when executing script. at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.addException(ScriptExecutor.java:199)
at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.addException(ScriptExecutor.java:176) at
org.eclipse.birt.report.engine.script.internal.ReportScriptExecutor.handleBeforeRender(ReportScriptExecutor.java:123) at
org.eclipse.birt.report.engine.api.impl.EngineTask.startRender(EngineTask.java:1376) at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRangeRender.render(RenderTask.java:510) at
org.eclipse.birt.report.engine.api.impl.RenderTask.render(RenderTask.java:209) at org.eclipse.birt.report.service.ReportEngineService.renderReport(ReportEngineService.java:1444) at
org.eclipse.birt.report.service.BirtViewerReportService.getPage(BirtViewerReportService.java:194) at
org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.doExecution(AbstractGetPageActionHandler.java:238) at
org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.__execute(AbstractGetPageActionHandler.java:105) at
org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90) at
org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47) at
org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143) at
org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPage(BirtDocumentProcessor.java:87) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37) at
java.lang.reflect.Method.invoke(Method.java:611) at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112) at
org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
java.lang.reflect.Method.invoke(Method.java:611) at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397) at
org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186) at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323) at
org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32) at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118) at
org.apache.axis.SimpleChain.invoke(SimpleChain.java:83) at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454) at org.apache.axis.server.AxisServer.invoke(AxisServer.java:
281) at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699) at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:616) at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327) at
javax.servlet.http.HttpServlet.service(HttpServlet.java:689) at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122) at
org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180) at
org.eclipse.equinox.http.servlet.internal.ServletRegistration.handleRequest(ServletRegistration.java:90) at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:111) at
org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:59) at javax.servlet.http.HttpServlet.service(HttpServlet.java:689) at
org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:269) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:428)
at org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHandler.java:677) at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:568) at
org.mortbay.http.HttpContext.handle(HttpContext.java:1530) at org.mortbay.http.HttpContext.handle(HttpContext.java:1482) at org.mortbay.http.HttpServer.service(HttpServer.java:909) at
org.mortbay.http.HttpConnection.service(HttpConnection.java:820) at org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:986) at
org.mortbay.http.HttpConnection.handle(HttpConnection.java:837) at org.mortbay.http.SocketListener.handleConnection(SocketListener.java:245) at
org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:357) at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:534) Caused by: org.eclipse.birt.core.exception.CoreException:
There are errors evaluating script "mmap = reportContext.getHttpServletRequest().getAttribute("attributeBean").getModuleOptions(); rptdoc =
reportContext.getHttpServletRequest().getAttribute("attributeBean").getReportDocumentName(); importPackage(Packages.org.eclipse.birt.report.engine.api); importPackage(Packages.java.io) var
re = reportContext.getReportRunnable().getReportEngine(); var mdocument = re.openReportDocument(null,rptdoc, mmap); var options = new PDFRenderOption(); baos = new
ByteArrayOutputStream(); options.setOutputFormat("xls"); options.setOutputStream(baos); var ntask = re.createRenderTask(mdocument); ntask.setRenderOption(options); ntask.render();
ntask.close(); mdocument.close(); fout = new FileOutputStream("c:/test/testLocale.xls"); fout.write(baos.toByteArray()); fout.flush() fout.close(); ": The choice of Java constructor write matching
JavaScript argument types ([B) is ambiguous; candidate constructors are: void write(int) void write(byte[]) (/report/method[@name="beforeRender"]#20). at
org.eclipse.birt.core.script.ScriptContext.eval(ScriptContext.java:307) at org.eclipse.birt.core.script.ScriptContext.eval(ScriptContext.java:335) at
org.eclipse.birt.report.engine.executor.ExecutionContext.evaluate(ExecutionContext.java:665) at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.handleJSInternal(ScriptExecutor.java:60)
at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.handleJS(ScriptExecutor.java:47) at
org.eclipse.birt.report.engine.script.internal.ReportScriptExecutor.handleBeforeRender(ReportScriptExecutor.java:115) ... 53 more Caused by: org.mozilla.javascript.EvaluatorException: The choice of
Java constructor write matching JavaScript argument types ([B) is ambiguous; candidate constructors are: void write(int) void write(byte[]) (/report/method[@name="beforeRender"]#20) at
org.mozilla.javascript.DefaultErrorReporter.runtimeError(DefaultErrorReporter.java:109) at org.mozilla.javascript.Context.reportRuntimeError(Context.java:1030) at
org.mozilla.javascript.Context.reportRuntimeError(Context.java:1086) at org.mozilla.javascript.Context.reportRuntimeError3(Context.java:1064) at
org.mozilla.javascript.NativeJavaMethod.findFunction(NativeJavaMethod.java:442) at org.mozilla.javascript.NativeJavaMethod.call(NativeJavaMethod.java:157) at
org.mozilla.javascript.optimizer.OptRuntime.call1(OptRuntime.java:66) at org.mozilla.javascript.gen.c7._c0(/report/method[@name="beforeRender"]:20) at org.mozilla.javascript.gen.c7.call(/
report/method[@name="beforeRender"]) at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:393) at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:2834)
at org.mozilla.javascript.gen.c7.call(/report/method[@name="beforeRender"]) at org.mozilla.javascript.gen.c7.exec(/report/method[@name="beforeRender"]) at
org.eclipse.birt.core.script.ScriptContext.eval(ScriptContext.java:302) ... 58 more
any idea how to make it work in 2.3.2
[Updated on: Sat, 25 May 2013 07:28] Report message to a moderator
FUDForum. Page generated in 0.03096 seconds
