PDE Build errors on xerces jar [message #65202] |
Mon, 22 June 2009 18:49 |
Originally posted by: udaykabe.yahoo.com
I am creating an automated build for my RCP product but the build fails with
the following error:
[java] BUILD FAILED
[java]
d:\JEE35RC4\eclipse\plugins\org.eclipse.pde.build_3.5.0.v200 90527-1800\scripts\productBuild\productBuild.xml:42:
The following error occurred while executing this line:
[java]
D:\JEE35RC4\eclipse\plugins\org.eclipse.pde.build_3.5.0.v200 90527-1800\scripts\build.xml:129:
[java] D:\WSDP\ws.kabe.news.build\customTargets.xml:26: The following
[java]
D:\JEE35RC4\eclipse\plugins\org.eclipse.pde.build_3.5.0.v200 90527-1800\scripts\productBuild\allElements.xml:20:
[java]
D:\JEE35RC4\eclipse\plugins\org.eclipse.pde.build_3.5.0.v200 90527-1800\scripts\genericTargets.xml:192:
[java]
d:\WSIDEBuild\package.org.eclipse.pde.build.container.featur e.all.xml:23:
[java]
d:\WSIDEBuild\package.org.eclipse.pde.build.container.featur e.all.xml:15:
[java]
D:\JEE35RC4\eclipse\plugins\org.eclipse.pde.build_3.5.0.v200 90527-1800\scripts\productBuild\allElements.xml:54:
[java]
d:\WSIDEBuild\package.org.eclipse.pde.build.container.featur e.win32.win32.x86.xml:100:
[java]
d:\WSIDEBuild\package.org.eclipse.pde.build.container.featur e.win32.win32.x86.xml:540:
d:\WSIDEBuild\tmp\news\plugins\org.apache.xerces_2.9.0.v2008 05270400 not
found.
The problem is that, within the zip task, the xerces jar is being
incorrectly identified as a directory instead of a jar file. It is being
copied properly earlier in the process as a jar file by the copy task.
Does anyone know how to fix this problem?
Thanks in advance.
Uday
Re: PDE Build errors on xerces jar [message #65224 is a reply to message #65202] |
Mon, 22 June 2009 19:06 |
I should clarify that I am wondering if anyone knows how to correctly
generate the
package.org.eclipse.pde.build.container.feature.win32.win32. x86.xml file.
Currently, I edit the file to correct the following and then re-run the
build at target "package" (obviously not good automation):
correct the problem in that file by changing this line:
<zipfileset
dir=" ${eclipse.base}/plugins/org.apache.xerces_2.9.0.v20080527040 0 "
prefix=" ${pluginArchivePrefix}/org.apache.xerces_2.9.0.v200805270400 " />
to this line:
<zipfileset
file=" ${eclipse.base}/plugins/org.apache.xerces_2.9.0.v20080527040 0.jar "
fullpath=" ${pluginArchivePrefix}/org.apache.xerces_2.9.0.v200805270400 .jar "
Thanks in advance.
Uday
"Uday Kabe" <udaykabe@yahoo.com> wrote in message
news:h1ojne$1cs$1@build.eclipse.org...
>with the following error:
> [java] BUILD FAILED
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> found.
> Thanks in advance.
> Uday
Re: PDE Build errors on xerces jar [message #65390 is a reply to message #65307] |
Tue, 23 June 2009 23:04 |
Thank you Andrew.
Yes, my product is based on features, and I did set unpack="false" for
xerces after which the build worked finished without error.
Interestingly, I also had unpack="true" for org.apache.lucene but that
setting did not abort the build. However, I
set unpack="false" for lucene as well just to be consistent.
Thanks again.
Uday
"Andrew Niefer" <aniefer@ca.ibm.com> wrote in message
news:h1qr1r$rdf$1@build.eclipse.org...
> Uday,
> I think you may be hitting this bug:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=265471
> Is your product based on features?
> If it is, you can edit the feature that includes org.apache.xerces so that
> it has unpack="false" for the xerces plugin:
> <plugin id="org.apache.xerces" version="0.0.0" unpack="false"/>
> -Andrew
>> generate the
>> <zipfileset
>> to this line:
>> <zipfileset
>> Thanks in advance.
>> Uday
>>> [java] BUILD FAILED
>>> [java]
>>> [java]
>>> [java]
>>> [java]
>>> [java]
>>> [java]
>>> [java]
>>> [java]
>>> [java]
>>> found.
>>> being copied properly earlier in the process as a jar file by the copy
>>> task.
>>> Thanks in advance.
>>> Uday
Re: PDE Build errors on xerces jar [message #598457 is a reply to message #65202] |
generate the
<zipfileset
to this line:
<zipfileset
Thanks in advance.
Uday
> [java] BUILD FAILED
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> found.
> Thanks in advance.
> Uday
Re: PDE Build errors on xerces jar [message #598512 is a reply to message #65307] |
Thank you Andrew.
Thanks again.
Uday
> Uday,
> -Andrew
>> generate the
>> <zipfileset
>> to this line:
>> <zipfileset
>> Thanks in advance.
>> Uday
>>> [java] BUILD FAILED
>>> [java]
>>> [java]
>>> [java]
>>> [java]
>>> [java]
>>> [java]
>>> [java]
>>> [java]
>>> [java]
>>> found.
>>> task.
>>> Thanks in advance.
>>> Uday
FUDForum. Page generated in 0.03465 seconds
