Acceleo 3 Problem with Stereotypes [message #649565] |
Wed, 19 January 2011 13:00  |
Hey there, i could use a little help. I am trying to generate code from an activity diagram made with MagicDraw
I finally understood how to go through the control flow of the diagram. Now i want to check, if a specific activity node has a pre-defined stereotype.
i tried something like this:
[template public generate_activities(a : Activity)]
[comment @main /]
[file (a.name.concat('Activity.java'), false, 'UTF-8')]
[for (i : InitialNode | a.ownedElement->filter(InitialNode))]
[getNodeFlow(i)/]
[/for]
[/file]
[/template]
[template public getNodeFlow(node : ActivityNode)]
[for (n: ActivityEdge | node.outgoing)]
[if not (n.target.oclIsKindOf(ActivityFinalNode))]
[n.target.name /]
[if (n.hasKeyword('stereotype'))]
gefunden
[/if]
[if (n.hasValue(stereotype,'ViewCall'))]
gefunden
[/if]
[getNodeFlow(n.target)/]
[/if]
[/for]
[/template]
apparently that is not working... thanks for your help...
Re: Acceleo 3 Problem with Stereotypes [message #649713 is a reply to message #649565] |
Thu, 20 January 2011 07:16   |
We will need a bit more information in order to help you:
1- could you give me the ouput of this :
[comment @main /]
[i/]
[/for]
[/file]
[/template]
Because in Acceleo, "i" is also an implicit counter for the "for" and we had a bug with this and since I don't know the version of Acceleo that you are using, you may be affected by the bug.
2- if "i" is not an integer but really an InitialNode, try this :
[comment @main /]
Step 0
Step 1
[getNodeFlow(i)/]
[/for]
[/file]
[/template]
Step 2
Step 3
Step 4: "[n/]"
[n.target.name /]
gefunden
[/if]
gefunden
[/if]
[/if]
[/for]
[/template]
What is the output ? (maybe one of your variable as not the type that you are imagining or maybe it is null, I don't know so let's try something simple)
Stephane Begaudeau, Obeo.
Re: Acceleo 3 Problem with Stereotypes [message #649958 is a reply to message #649767] |
Fri, 21 January 2011 03:22  |
--------------080904010307020309010409
Glad to see you managed :). That may not be the case here, but do not
hesitate to raise enhancement requests when you think that Acceleo could
have helped more (compilation warning, error message ...).
Laurent Goubet
Obeo
On 20/01/2011 15:53, woife wrote:
> Ok,
> sorry to have bothered you... i found my own error in the loop. i made a
> mistake...
> the correct code for the second template has to be:
> [n.target.name /]
> [for (ns: Stereotype | n.target.getAppliedStereotypes())]
> gefunden
> [ns.name /]
> [/for]
> [/if]
> [/for]
> [/template]
> and it works! ;)
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------080904010307020309010409--
FUDForum. Page generated in 0.05844 seconds
