Lockfile Error while importing repository [message #649416] |
Wed, 19 January 2011 08:12 |
Me Messages: 1 Registered: January 2011 |
I've tried to import a repository from github.
So I went through File -> Import -> Projects From Git -> Clone... -> Entered URL -> Chose a directory
Everything worked fine, the wizard then started to download the repository but after the download, it throws an error.
Message: Git repository clone failed.
Exception Stack Trace:
java.io.IOException: Could not delete file C:\foo\bar\eclipseworkspace\sipxecs\.git\index.lock
at org.eclipse.jgit.util.FileUtils.delete(FileUtils.java:133)
at org.eclipse.jgit.util.FileUtils.delete(FileUtils.java:118)
at org.eclipse.egit.core.op.CloneOperation.run(CloneOperation.java:142)
at org.eclipse.egit.ui.internal.clone.GitCloneWizard.executeCloneOperation(GitCloneWizard.java:254)
at org.eclipse.egit.ui.internal.clone.GitCloneWizard.access$3(GitCloneWizard.java:247)
at org.eclipse.egit.ui.internal.clone.GitCloneWizard$3.run(GitCloneWizard.java:211)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
I have no idea why the lockfile can't be deleted.
I already tried to download the repository from a https and from a git source.
I also chose different local directories to prevent folder restrictions.
Anyone can help?
My System Spec:
Win7 Professional 64 Bit
Eclipse Helios Build id: 20100917-0705
EGit Version 0.10.1
Greetz, Me
[Updated on: Wed, 19 January 2011 08:23] Report message to a moderator
FUDForum. Page generated in 0.03353 seconds
