CLI Workspaces & Projects [message #649117] |
Mon, 17 January 2011 18:11 |
Hilco Wijbenga Messages: 1 Registered: July 2009 Location: Richmond, BC |
Hi all,
I know that "how do I share a workspace" has come up several times before and the usual answer is "you can't" and "you should share projects". Unfortunately, (AFAIK) this has not changed. In fact, things have gotten worse because now I can't even easily share projects anymore (it seems that the GWT Eclipse plugin that I'm using inserts hard coded filesystem locations).
The main problem, however, is the workspace because it's much bigger, has far more hard-coded user/OS specific entries, and some entries are (or appear to be) binary instead of text. Not to mention that it's the workspace that stores all the really juicy properties. I have tried using import and export but clearly only a subset of the workspace entries are exported/imported.
So I was hoping to solve all my problems by going a bit more low level. Is there a CLI or even a Java API that I could use to create a workspace? And projects? The things that I am specifically interested in are:
* automatically downloading, installing, and configuring required plugins (i.e. required for our project);
* automatically configuring compiler warnings/errors, code clean-up rules, code formatting rules, checkstyle, and PMD.
Pointers and hints on where to look and how to get started would be greatly appreciated.
Hilco
FUDForum. Page generated in 0.01368 seconds
