Home » Newcomers » Newcomers » No more Sun Java in Ubuntu, which Java to use with Eclipse?(The relevant sticky thread is outdated)
No more Sun Java in Ubuntu, which Java to use with Eclipse? [message #649111] Mon, 17 January 2011 12:38 Go to next message
As a new Eclipse user on Kubuntu 10.10, I found this important thread:
http://www.eclipse.org/forums/index.php?t=msg&th=161212& amp;start=0&S=1df82ee243e19a7de2cb0ff2df039bf0
The recommended Java install, sun-jdk-*, no longer exists in the Ubuntu repos:
$ aptitude search jdk | grep sun
$ aptitude search java | grep sun
p   libsunflow-java                 - rendering system for photo-realistic image
p   libsunflow-java-doc             - rendering system for photo-realistic image
p   sun-javadb-client               - Java DB client
p   sun-javadb-common               - Java DB common files
p   sun-javadb-core                 - Java DB core
p   sun-javadb-demo                 - Java DB demo
p   sun-javadb-doc                  - Java DB documentation
p   sun-javadb-javadoc              - Java DB javadoc
Should I go ahead an use the gcj java, or should I switch to the openjdk Java?
Thanks!
Re: No more Sun Java in Ubuntu, which Java to use with Eclipse? [message #649118 is a reply to message #649111] Mon, 17 January 2011 13:18 Go to previous messageGo to next message
> repos:
> p sun-javadb-client - Java DB client p sun-javadb-common - Java DB
> common files p sun-javadb-core - Java DB core p sun-javadb-demo - Java
> DB demo p sun-javadb-doc - Java DB documentation p sun-javadb-javadoc -
> Java DB javadoc $
> Java?
> Thanks!
In my opinion, you shouldn't worry about what JRE you're using for your
computer host. Always download and point Eclipse at a Sun JDK (JRE) that
doesn't change. That way, your host-wide JRE can be updated as desired
and appropriate while the one Eclipse runs on is always and only the one
you decide yourself.
Re: No more Sun Java in Ubuntu, which Java to use with Eclipse? [message #649141 is a reply to message #649111] Mon, 17 January 2011 15:36 Go to previous messageGo to next message
> Thanks!
The Sun jdk is available in the Ubuntu repos. You need to enable
partner repos to pick it up. Here is a link with instructions.
http://www.liberiangeek.net/2010/10/sun-java-runtime-jre-ubu ntu-10-10-maverick-meerkat-partner-repository/
Re: No more Sun Java in Ubuntu, which Java to use with Eclipse? [message #649142 is a reply to message #649111] Mon, 17 January 2011 15:38 Go to previous messageGo to next message
Just download any Sun/Oracle JDK and install it in /opt. Then fiddle a
bit with alternatives and /etc/environment and you are done. Besides the
original JDK it gives you indepnendency from the Ubuntu release plan. I
never had an issue with a Sun JDK on Ubuntu for about five years now.
HTH
Michael
Re: No more Sun Java in Ubuntu, which Java to use with Eclipse? [message #649157 is a reply to message #649118] Mon, 17 January 2011 17:51 Go to previous message
Thanks, David, that link was just what I needed. I do prefer to use my distro's available repos instead of downloading everything from the original project's homepage.
Have a great evening!
Previous Topic:Set a path in options referencing current workspace - possible?
Next Topic:Problem With JUnit in Lesson 6
Current Time: Sun Nov 02 05:13:24 EST 2025
Powered by FUDForum. Page generated in 0.07979 seconds
