Re: Set label of marker in a chart [message #648832 is a reply to message #648738] |
Fri, 14 January 2011 16:27 |
Add
importPackage(Packages.org.eclipse.birt.chart.model.componen t.impl)
right above where you calculate the min_value.
Jason
On 1/14/2011 6:00 AM, Klaus Meisl wrote:
> I want to change the label of a marker in a chart via script. I use
> beforeDrawMarkerLine function (see below). The following (setLabel) does
> not work (this error:
> Can't find method
> org.eclipse.birt.chart.model.component.impl.MarkerLineImpl.s etLabel(string).
> at line 19 of chart script:'')
> Perhaps anybody can give me a hint. thanks.
> function beforeDrawMarkerLine(axis, markerLine, icsc)
> importPackage( Packages.org.eclipse.birt.chart.model.data.impl );
> var min_value =
> icsc.getExternalContext().getScriptable().getPersistentGloba lVariable( "min_val");
> markerLine.setValue(NumberDataElementImpl.create(min_value)) ;
> markerLine.setLabel("Value: " + min_value);
Re: Set label of marker in a chart [message #648873 is a reply to message #648832] |
Fri, 14 January 2011 18:34 |
Klaus Meisl Messages: 90 Registered: July 2009 |
Member |
Jason,
setting the line works fine, it just does not set the label of the line.
My script now looks like this, but the error remains.
importPackage(Packages.org.eclipse.birt.chart.model.data.imp l);
importPackage(Packages.org.eclipse.birt.chart.model.componen t.impl);
var min_value =
// works fine so far
// this does not work
markerLine.setLabel("This is the line");
Am 14.01.11 17:27, schrieb Jason Weathersby:
> Add
> Jason
>> Can't find method
>> var min_value =
Re: Set label of marker in a chart [message #649119 is a reply to message #648873] |
Mon, 17 January 2011 18:32 |
Try:
markerLine.getLabel().getCaption().setValue("Test");
On 1/14/2011 1:34 PM, Klaus Meisl wrote:
> Jason,
> var min_value =
>> Add
>> Jason
>>> Hi,
>>> Can't find method
>>> var min_value =
FUDForum. Page generated in 0.03208 seconds
