Home » Eclipse Projects » Rich Client Platform (RCP) » Widget <-> View (ID)(How can I get the View ID given a Widget reference?)
Re: Widget <-> View (ID) [message #648549 is a reply to message #648499] |
Thu, 13 January 2011 13:26 |
On 01/13/2011 04:21 AM, PigsAngel wrote:
> Thanks, I suspected that was the answer.
> This information would be useful for simplifying the writing of GUI test
> cases, but I presume we have to find other ways to solve this.
If you know before hand, you can set IDs on your widgets and use them in
your UI test cases.
i.e. in your viewpart, you create buttons and use
button.setData("test.id", "button1")
Then when walking your view, you can find "button1" for your tests and
when button 1 is clicked you can check that ID in your tests, etc.
Depending on the size of your app, you might only want to set the data
when in test mode.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Paul Webster
Current Time: Thu Apr 25 07:23:10 GMT 2024
Powered by FUDForum. Page generated in 0.03221 seconds
