Re: Chart Added Error (Loader can not resolve Rhino classes) [message #648193 is a reply to message #648187] |
Tue, 11 January 2011 17:54 |
Are you using the allinone download?
What jvm are you using?
Jason
On 1/11/2011 11:48 AM, Cenk Dundar wrote:
> Hi;
> I am using Birt 2.6.1 on eclipse 3.6. When I try to Add chart the error
> occured.
> What is the problem.?
> The Message (Show Trace) is
> org.eclipse.birt.chart.reportitem.ui.ReportDataServiceProvid er.initialize(ReportDataServiceProvider.java:279)
> org.eclipse.birt.chart.ui.swt.wizard.preview.ChartLivePrevie wThread.initDataEngine(ChartLivePreviewThread.java:237)
> org.eclipse.birt.chart.ui.swt.wizard.preview.ChartLivePrevie wThread.run(ChartLivePreviewThread.java:153)
> Caused By:Loader can not resolve Rhino classes
> org.mozilla.javascript.Context.setApplicationClassLoader(Con text.java:2306)
> org.eclipse.birt.report.engine.javascript.JavascriptEngine.s etApplicationClassLoader(JavascriptEngine.java:325)
> org.eclipse.birt.core.script.ScriptContext.createEngine(Scri ptContext.java:244)
> org.eclipse.birt.core.script.ScriptContext.getScriptEngine(S criptContext.java:230)
> org.eclipse.birt.report.engine.adapter.ModelDteApiAdapter.<init >(ModelDteApiAdapter.java:177)
> org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.<init >(AbstractDataEngine.java:107)
> org.eclipse.birt.report.engine.data.dte.DteDataEngine.<init >(DteDataEngine.java:85)
> org.eclipse.birt.report.engine.data.DataEngineFactory.create DataEngine(DataEngineFactory.java:100)
> org.eclipse.birt.report.engine.executor.ExecutionContext.ope nDataEngine(ExecutionContext.java:837)
> org.eclipse.birt.report.engine.executor.ExecutionContext.get DataEngine(ExecutionContext.java:854)
> org.eclipse.birt.report.engine.api.impl.EngineTask.getDataSe ssion(EngineTask.java:525)
> org.eclipse.birt.chart.reportitem.ui.ReportDataServiceProvid er.initialize(ReportDataServiceProvider.java:257)
Re: Chart Added Error (Loader can not resolve Rhino classes) [message #648627 is a reply to message #648435] |
Thu, 13 January 2011 17:06 |
As a test can you try the allinone?
Jason
On 1/12/2011 5:15 PM, Cenk Dundar wrote:
> No(note allinone). I have installed on eclipse (after)
> My JVM is 1.6.0_23.
> "Jason Weathersby"<jasonweathersby@windstream.net> wrote in message
> news:igi56n$i6$2@news.eclipse.org...
>> Jason
>>> Hi;
>>> occured.
Re: Chart Added Error (Loader can not resolve Rhino classes) [message #648830 is a reply to message #648714] |
Fri, 14 January 2011 16:22 |
I meant for you to install the allinone in a separate location on the
same machine. It should not effect your current install.
Jason
On 1/14/2011 3:07 AM, Cenk Dundar wrote:
> Nowadays It is not possible. Because I installed alot of plugin.
> What is the problem
> news:ignb4e$a30$1@news.eclipse.org...
>> Jason
>>> My JVM is 1.6.0_23.
>>>> Jason
>>>>> Hi;
>>>>> occured.
FUDForum. Page generated in 0.02556 seconds
