Home » Modeling » EMF » Transient eOpposite of a persistent eRef?
Re: Transient eOpposite of a persistent eRef? [message #648402 is a reply to message #648182] |
Wed, 12 January 2011 17:38 |
Hallvard Traetteberg Messages: 673 Registered: July 2009 Location: Trondheim, Norway |
On 11.01.11 17.21, Ed Merks wrote:
> Caspar,
> Comments below.
> Caspar D. wrote:
>> Generally speaking, does it ever make sense to have transient=true
>> for the eOpposite of a *persistent* eRef? Or is this a modeling
>> error?
> If the reference isn't proxy resolving then the reference will have to
> be in the same resource and one could expect a deserializer to fully
> populate both ends by populating just one end.
I have considered a setup where this seem to make sense:
I have many independent graph in separate resource, which can be
considered independent models. I want a separate 'parent' resource to
refer to these using containment, so that they seem to be within the
parent, but still possible to load independently. I.e. the parent's
containment reference must have transient = false (and resolve proxies),
while the eOpposite eContainer from the root of the independent trees to
the parent must have transient = true. Hence, if I load the independent
trees, they don't load the parent, while the parent loads the children.
Hallvard
Re: Transient eOpposite of a persistent eRef? [message #648405 is a reply to message #648402] |
Wed, 12 January 2011 17:54 |
Hi Hallvard,
I may be wrong but I think container references implicitely share the persistence settings of their containment opposite.
Cheers
/Eike
http://www.esc-net.de
Am 12.01.2011 18:38, schrieb Hallvard Trætteberg:
>> Caspar,
>> Comments below.
>>> error?
> I have many independent graph in separate resource, which can be considered independent models. I want a separate 'parent' resource to refer to these using containment, so that they seem to be within the parent, but still possible to load independently. I.e. the parent's containment reference must have transient = false (and resolve proxies), while the eOpposite eContainer from the root of the independent trees to the parent must have transient = true. Hence, if I load the independent trees, they don't load the parent, while the parent loads the children.
> Hallvard
Cheers
/Eike
Re: Transient eOpposite of a persistent eRef? [message #649208 is a reply to message #648403] |
Tue, 18 January 2011 08:13 |
> Why containment?
It's a model of a widget hierarchy, and I want to be able to split
existing models into parent/child parts, i.e. cut off arbitrary branches
and put them into a separate resources while still being contained by
their parents. These separate widget containers must be loadable without
loading the rest the parent. BTW, I don't need to model the parent
reference, but I guess the eContainer is automatically the eOpposite of
the containment reference.
>> independently.
> Non-containment would work perfectly for that.
Hallvard
Re: Transient eOpposite of a persistent eRef? [message #649291 is a reply to message #649208] |
Tue, 18 January 2011 15:59 |
Ed Merks Messages: 33141 Registered: July 2009 |
Hallvard,
Comments below.
>> Why containment?
> branches and put them into a separate resources while still being
> contained by their parents. These separate widget containers must be
> loadable without loading the rest the parent.
That seems reasonable. Note that it's always possible to load without
loading any references. In fact it's only as you traverse references
that proxies are resolved and of course it's possible to traverse
references without resolving proxies as well.
> BTW, I don't need to model the parent reference, but I guess the
> eContainer is automatically the eOpposite of the containment reference.
Yes, containments always have eContainer as their implicit opposite.
>>> independently.
> Hallvard
Ed Merks
Re: Transient eOpposite of a persistent eRef? [message #1053230 is a reply to message #648124] |
Fri, 03 May 2013 09:27 |
Cristian Spiescu Messages: 100 Registered: July 2009 |
I continue this thread, because I have a question on this particular topic.
a) I have several resources that contain UML-like model elements (Class, attribute, etc)
b) I have a diagram that contains notation model elements that reference the above UML-like model elements. So far so good, we need an uni-directional reference.
c) I want to be able to navigate rapidly from the UML-like model elements to the corresponding diagrams. So the uni-directional reference above, becomes bi-directional; e.g. a list called "diagrams".
d) But the above reference: I want it to be transient, so that my resources (with UML-like model elements) don't depend on the diagrams.
What I would like:
when I load an UML-like model element:
1) if no diagrams are loaded => the list "diagrams" is empty
2) if I load a diagram that references this model element, then I would like my transient list to contain the newly loaded diagram.
The question:
I can achieve this, by modifying the generated setter of the diagram/notation model elements: if the EObject parameter is proxy => resolve it before setting it. This would ensure that during load of the diagram, all proxies are resolved, so the transient list is correctly populated.
Are there pitfalls related to this approach? I.e. resolving a EObject proxy in the setter?
Thank you in advance.
Cristian.
Re: Transient eOpposite of a persistent eRef? [message #1053233 is a reply to message #1053230] |
Fri, 03 May 2013 09:49 |
Cristian,
Comments below.
On 03/05/2013 11:27 AM, Cristian Mising name wrote:
> Hello,
> topic.
This is not a good idea. Suppose one said "I always want to rapidly
navigate both directions of all references" one could conclude, "there
all references because directional" but this is simply an unworkable
solution. An example of this is like EClass.eSuperTypes. Sure it's
quite often I want to navigate to all subclass, but it's still not
reasonable to make this reference bidirectional. We can't expect that
an EClass will always know all subclasses. It just can't know that and
it can't be expected to store such information.
See, you're going down a rat hole now... The model should not even know
about diagrams...
> What I would like: when I load an UML-like model element:
Yes, you might like that, but it's not a reasonable expectation.
> The question:
No, it's a rat hole. You'll die down there.
This is the type of thing that an ECrossReferenceAdapter is for, i.e.,
rapid inverse navigation of unidirectional references.
> Regards,
> Cristian.
Ed Merks
Current Time: Thu Apr 25 16:26:54 GMT 2024
Powered by FUDForum. Page generated in 0.03574 seconds
