helios build path problem [message #648119] |
Tue, 11 January 2011 10:12 |
Glen Messages: 5 Registered: January 2011 |
HI everyone, need your help please ...
I am getting errors opening the EPF source code that I've got from an external resource but Im having errors on build path
The container 'Persisted container [org.eclipse.pde.core.requiredPlugins for project [org.eclipse.epf.authoring.ui]]' references non existing library 'D:\Program Files (x86)\Eclipse\EPFC_Dev_33\eclipse\plugins\com.ibm.icu_3.6.1. v20070906.jar'
I know that the build path that the external resource used was located on his local machine . How can I modify this using my machine?
I am using helios in opening this.
Thank you
[Updated on: Tue, 11 January 2011 10:42] Report message to a moderator
FUDForum. Page generated in 0.03572 seconds
