Home » Archived » BIRT » Pie chart problem(Pie chart problem)
Pie chart problem [message #648116] |
Tue, 11 January 2011 10:07 |
Aby Messages: 3 Registered: September 2010 Location: India |
Hi everybody i am running the pie chart application it shows pie chart in the report preview in eclipse but when i am running pie chart from the browser
it shows following error can any one fix this problem?
The design file file:/opt/apache-tomcat-7.0.4/webapps/educompaq/report/pieCh art.rptdesign has error and can not be run.
org.eclipse.birt.report.engine.api.EngineException: The design file file:/opt/apache-tomcat-7.0.4/webapps/educompaq/report/pieCh art.rptdesign has error and can not be run.
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:248)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:191)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:125)
at org.eclipse.birt.report.engine.api.impl.ReportEngine.openRep ortDesign(ReportEngine.java:239)
at birtReport.Birt.design(Birt.java:58)
at birtReport.reportAction.pieChartReport(reportAction.java:298 )
at com.opensymphony.xwork2.DefaultActionInvocation.invokeAction (DefaultActionInvocation.java:441)
at com.opensymphony.xwork2.DefaultActionInvocation.invokeAction Only(DefaultActionInvocation.java:280)
at com.opensymphony.xwork2.DefaultActionInvocation.invoke(Defau ltActionInvocation.java:243)
at com.opensymphony.xwork2.interceptor.DefaultWorkflowIntercept or.doIntercept(DefaultWorkflowInterceptor.java:165)
at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor. intercept(MethodFilterInterceptor.java:87)
at com.opensymphony.xwork2.DefaultActionInvocation.invoke(Defau ltActionInvocation.java:237)
at com.opensymphony.xwork2.validator.ValidationInterceptor.doIn tercept(ValidationInterceptor.java:252)
at org.apache.struts2.interceptor.validation.AnnotationValidati onInterceptor.doIntercept(AnnotationValidationInterceptor.ja va:68)
at com.opensymphony.xwork2.interceptor.ConversionErrorIntercept or.intercept(ConversionErrorInterceptor.java:122)
at com.opensymphony.xwork2.interceptor.ParametersInterceptor.do Intercept(ParametersInterceptor.java:195)
at com.opensymphony.xwork2.interceptor.StaticParametersIntercep tor.intercept(StaticParametersInterceptor.java:179)
at org.apache.struts2.interceptor.MultiselectInterceptor.interc ept(MultiselectInterceptor.java:75)
at org.apache.struts2.interceptor.CheckboxInterceptor.intercept (CheckboxInterceptor.java:94)
at org.apache.struts2.interceptor.FileUploadInterceptor.interce pt(FileUploadInterceptor.java:235)
at com.opensymphony.xwork2.interceptor.ModelDrivenInterceptor.i ntercept(ModelDrivenInterceptor.java:89)
at com.opensymphony.xwork2.interceptor.ScopedModelDrivenInterce ptor.intercept(ScopedModelDrivenInterceptor.java:130)
at org.apache.struts2.interceptor.debugging.DebuggingIntercepto r.intercept(DebuggingInterceptor.java:267)
at com.opensymphony.xwork2.interceptor.ChainingInterceptor.inte rcept(ChainingInterceptor.java:126)
at com.opensymphony.xwork2.interceptor.PrepareInterceptor.doInt ercept(PrepareInterceptor.java:138)
at com.opensymphony.xwork2.interceptor.I18nInterceptor.intercep t(I18nInterceptor.java:165)
at org.apache.struts2.interceptor.ServletConfigInterceptor.inte rcept(ServletConfigInterceptor.java:164)
at com.opensymphony.xwork2.interceptor.AliasInterceptor.interce pt(AliasInterceptor.java:179)
at com.opensymphony.xwork2.interceptor.ExceptionMappingIntercep tor.intercept(ExceptionMappingInterceptor.java:176)
at org.apache.struts2.impl.StrutsActionProxy.execute(StrutsActi onProxy.java:52)
at org.apache.struts2.dispatcher.Dispatcher.serviceAction(Dispa tcher.java:488)
at org.apache.struts2.dispatcher.FilterDispatcher.doFilter(Filt erDispatcher.java:395)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:242)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:208)
at org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:240)
at org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:203)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:164)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:108)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogVa lve.java:558)
at org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:379)
at org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:242)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:259)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:237)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(J IoEndpoint.java:281)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unkno wn Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Caused by: Error.DesignFileException.SYNTAX_ERROR - 12 errors found!
1.) ( line = 181, tag = extended-item) (Element = ExtendedItem, Name = null), org.eclipse.birt.report.model.api.command.NameException (code = Error.NameException.NAME_REQUIRED, message : The name of report.Body[0] is required.)
2.) ( line = 8, tag = property) org.eclipse.birt.report.model.parser.DesignParserException (code = Error.DesignParserException.UNDEFINED_PROPERTY, message : The property "bidiLayoutOrientation" is not defined.)
3.) ( line = 9, tag = property) org.eclipse.birt.report.model.parser.DesignParserException (code = Error.DesignParserException.UNDEFINED_PROPERTY, message : The property "imageDPI" is not defined.)
4.) ( line = 34, tag = text-property) org.eclipse.birt.report.model.parser.DesignParserException (code = Error.DesignParserException.UNDEFINED_PROPERTY, message : The property "heading" is not defined.)
5.) ( line = 35, tag = property) org.eclipse.birt.report.model.parser.DesignParserException (code = Error.DesignParserException.UNDEFINED_PROPERTY, message : The property "displayLength" is not defined.)
6.) ( line = 36, tag = property) org.eclipse.birt.report.model.parser.DesignParserException (code = Error.DesignParserException.UNDEFINED_PROPERTY, message : The property "horizontalAlign" is not defined.)
7.) ( line = 37, tag = property) org.eclipse.birt.report.model.parser.DesignParserException (code = Error.DesignParserException.UNDEFINED_PROPERTY, message : The property "wordWrap" is not defined.)
8.) ( line = 42, tag = text-property) org.eclipse.birt.report.model.parser.DesignParserException (code = Error.DesignParserException.UNDEFINED_PROPERTY, message : The property "heading" is not defined.)
9.) ( line = 43, tag = property) org.eclipse.birt.report.model.parser.DesignParserException (code = Error.DesignParserException.UNDEFINED_PROPERTY, message : The property "displayLength" is not defined.)
10.) ( line = 44, tag = property) org.eclipse.birt.report.model.parser.DesignParserException (code = Error.DesignParserException.UNDEFINED_PROPERTY, message : The property "horizontalAlign" is not defined.)
11.) ( line = 45, tag = property) org.eclipse.birt.report.model.parser.DesignParserException (code = Error.DesignParserException.UNDEFINED_PROPERTY, message : The property "wordWrap" is not defined.)
12.) ( line = 1041, tag = property) org.eclipse.birt.report.model.parser.DesignParserException (code = Error.DesignParserException.UNDEFINED_PROPERTY, message : The property "inheritColumns" is not defined.)
at org.eclipse.birt.report.model.parser.ModuleParserHandler.end Document(ModuleParserHandler.java:269)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .endDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.birt.report.model.parser.ModuleReader.readModule (ModuleReader.java:95)
at org.eclipse.birt.report.model.parser.DesignReader.read(Desig nReader.java:90)
at org.eclipse.birt.report.model.core.DesignSession.openDesign( DesignSession.java:316)
at org.eclipse.birt.report.model.api.SessionHandle.openDesign(S essionHandle.java:292)
at org.eclipse.birt.report.engine.parser.ReportParser.getDesign Handle(ReportParser.java:158)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:243)
... 73 more
thanks in advance......
Re: Pie chart problem [message #648192 is a reply to message #648116] |
Tue, 11 January 2011 17:53 |
Can you post the report?
Jason
> the browser it shows following error can any one fix this problem?
> The design file
> onProxy.java:52)
> tcher.java:488)
> stValve.java:164)
> rtValve.java:108)
> lve.java:558)
> apter.java:379)
> ssor.java:242)
> Caused by: Error.DesignFileException.SYNTAX_ERROR - 12 errors found! 1.)
> is required.)
> Source)
> nReader.java:90)
> ... 73 more
Re: Pie chart problem [message #648255 is a reply to message #648192] |
Wed, 12 January 2011 05:47 |
Hey, this is my report.
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.15" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.6.0.v20100531 Build <2.6.0.v20100609-1613></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">60</property>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="dataSource_name" id="8">
<list-property name="privateDriverProperties">
<ex-property>
<name>contentBidiFormatStr</name>
<value>ILYNN</value>
</ex-property>
<ex-property>
<name>metadataBidiFormatStr</name>
</ex-property>
</list-property>
<property name="odaDriverClass">com.mysql.jdbc.Driver</property>
<property name="odaURL">jdbc:mysql://localhost:3306/database_name</property>
<property name="odaUser">root</property>
<encrypted-property name="odaPassword" encryptionID="base64">QWRtaW4=</encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="Data Set" id="9">
<list-property name="columnHints">
<structure>
<property name="columnName">product_id</property>
<text-property name="displayName">product_id</text-property>
<text-property name="heading">product_id</text-property>
<property name="displayLength">10</property>
<property name="horizontalAlign">justify</property>
<property name="wordWrap">false</property>
</structure>
<structure>
<property name="columnName">product_name</property>
<text-property name="displayName">product_name</text-property>
<text-property name="heading">product_name</text-property>
<property name="displayLength">128</property>
</structure>
<structure>
<property name="columnName">quantity</property>
<text-property name="displayName">quantity</text-property>
<text-property name="heading">quantity</text-property>
<property name="displayLength">20</property>
</structure>
<structure>
<property name="columnName">unit_id</property>
<text-property name="displayName">unit_id</text-property>
<text-property name="heading">unit_id</text-property>
</structure>
<structure>
<property name="columnName">unit_of_measurement</property>
<text-property name="displayName">unit_of_measurement</text-property>
<text-property name="heading">unit_of_measurement</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">product_id</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">product_name</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">quantity</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">unit_id</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">unit_of_measurement</property>
</structure>
</list-property>
</structure>
<property name="dataSource">dataSource_name</property>
<structure>
<property name="nativeName">product_id</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">product_name</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">quantity</property>
</structure>
<structure>
<property name="nativeName">unit_id</property>
</structure>
<structure>
<property name="nativeName">unit_of_measurement</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[SELECT * FROM product_price_master ]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>product_id</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>NotNullable</design:nullability>
<design:uiHints>
<design:displayName>product_id</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>product_id</design:label>
<design:formattingHints>
<design:displaySize>10</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>product_name</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>128</design:precision>
<design:uiHints>
<design:displayName>product_name</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>product_name</design:label>
<design:displaySize>128</design:displaySize>
<design:attributes>
<design:name>quantity</design:name>
<design:position>3</design:position>
<design:precision>20</design:precision>
<design:uiHints>
<design:displayName>quantity</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>quantity</design:label>
<design:displaySize>20</design:displaySize>
<design:attributes>
<design:name>unit_id</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>unit_id</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>unit_id</design:label>
<design:attributes>
<design:name>unit_of_measurement</design:name>
<design:position>5</design:position>
<design:uiHints>
<design:displayName>unit_of_measurement</design:displayName >
</design:uiHints>
<design:usageHints>
<design:label>unit_of_measurement</design:label>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<extended-item extensionName="Chart" id="10">
<xml-property name="xmlRepresentation"><![CDATA[<model:ChartWithoutAxes xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute" xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout" xmlns:model="http://www.birt.eclipse.org/ChartModel" xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Version>2.5.1</Version>
<Type>Pie Chart</Type>
<SubType>Standard</SubType>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Visible>true</Visible>
<Label>
<Caption>
<Value>Product Quantity</Value>
<Font>
<Name>Arial</Name>
<Size>16.0</Size>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Right</Position>
<ItemType>Categories</ItemType>
<Title>
<Caption>
<Value>Product Name</Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Above</TitlePosition>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>212.0</Width>
<Height>130.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<GridColumnCount>0</GridColumnCount>
<ExtendedProperties>
<Name>enable.area.alt</Name>
<Value>false</Value>
</ExtendedProperties>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>'A','B','C','D','E'</DataSetRepresentation >
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>6,4,12,8,10</DataSetRepresentation>
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
</SampleData>
<Interactivity>
<Enable>true</Enable>
<LegendBehavior>None</LegendBehavior>
</Interactivity>
<EmptyMessage>
<Caption>
<Value>This chart contains no data.</Value>
<Font>
<Alignment>
</Alignment>
</Font>
</Caption>
<Transparency>64</Transparency>
<Red>127</Red>
<Green>127</Green>
<Blue>127</Blue>
</Background>
<Outline>
<Color>
<Transparency>128</Transparency>
<Red>127</Red>
<Green>127</Green>
<Blue>127</Blue>
</Color>
</Outline>
<Insets>
<Top>10.0</Top>
<Left>10.0</Left>
<Bottom>10.0</Bottom>
<Right>10.0</Right>
</Insets>
</EmptyMessage>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series xsi:type="type:PieSeries">
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["quantity"]</Definition>
<Grouping>
<GroupType>Text</GroupType>
<AggregateExpression>Sum</AggregateExpression>
</Grouping>
</DataDefinition>
<SeriesIdentifier>Series 1</SeriesIdentifier>
<DataPoint>
<Components>
<Type>Orthogonal_Value</Type>
</Components>
<Separator>, </Separator>
</DataPoint>
<LabelPosition>Outside</LabelPosition>
<Stacked>false</Stacked>
<Explosion>0</Explosion>
<Title>
<Caption>
<Value></Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<LeaderLineAttributes>
</LeaderLineAttributes>
<LeaderLineStyle>Fixed_Length</LeaderLineStyle>
<LeaderLineLength>10.0</LeaderLineLength>
</Series>
<Grouping>
</Grouping>
</SeriesDefinitions>
<Series>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["product_name"]</Definition >
</DataDefinition>
<SeriesIdentifier></SeriesIdentifier>
<DataPoint>
<Components>
</Components>
</DataPoint>
</Series>
<Grouping>
<Enabled>true</Enabled>
</Grouping>
</model:ChartWithoutAxes>
]]></xml-property>
<property name="outputFormat">SVG</property>
<property name="inheritColumns">true</property>
<property name="dataSet">Data Set</property>
<property name="height">130pt</property>
<property name="width">212pt</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression" type="javascript">dataSetRow["product_id"]</expression>
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["product_name"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["quantity"]</expression>
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["unit_id"]</expression>
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["unit_of_measurement"]</expression >
</structure>
</list-property>
</extended-item>
</body>
</report>
Current Time: Sat Apr 20 00:06:18 GMT 2024
Powered by FUDForum. Page generated in 0.03415 seconds
