Java Swing bug or error in program?? [message #648076] |
Tue, 11 January 2011 06:12 |
Niranjani S Messages: 3 Registered: August 2010 |
I have an ActionListener attached to a JComboBox(uneditable). Once an item from the JComboBox is selected, I have to make the next button in the frame visible.
The skeleton of the code looks like this:
public void actionPerformed(ActionEvent evt)
if(evt.getSource()==jComboBox){
if(jComboBox.getSelectedIndex()==-1)
//Display an alert message
else{
nextButton.setVisible(true);
//Do other actions
It is found that actionPerformed is called only when the second, third, fourth (and so on) items are selected. But actionPerformed is not called when the first item is selected the very first time. But if the first item is selected after selecting other items actioPerformed gets called and the code works fine.
This error appears on some systems and doesn't on other systems. Any help in this regard would be appreciated.
Thanks in Advance!!
FUDForum. Page generated in 0.02563 seconds
