Re: Regressions with Graphiti 0.8.0M4 and GEF 3.7 [message #648188 is a reply to message #647887] |
Tue, 11 January 2011 16:15   |
Michael Wenz Messages: 1923 Registered: July 2009 Location: Walldorf, Germany |
I was able to reproduce the zoom animation issue. This seems to be
introduced with GEF 3.7 (directly comparing the behavior of GEF 3.6 and 3.7
is now possible, the head CVS revision runs against both again).
But I could not reproduce the sizing issue in zoom level 1000. Do you have
more details on that?
Michael
"Romain Raugi" <romain.raugi@fr.ibm.com> wrote in message
news:igemse$biu$1@news.eclipse.org...
> I noticed two issues while testing the last milestone of Graphiti (0.8.0M4
> from the CVS) against GEF 3.7.
> - The zoom animation does not work anymore when a graphic object is
> selected. You can observe this behavior using the tutorial sample.
> - With a zoom level different than 100%, it is difficult to create a shape
> of an expected area (seems to not match the zoom level). Using the
> tutorial sample:
> * Set a zoom level of 1000%
> * Click on a UMLClass in the palette.
> * Mouse down and drag operation in the diagram.
> * Drop, the object has not the expected size.
> There have been refactorings done in GEF (impacting the CreationTool),
> which can explain such issue.
> Romain
Re: Regressions with Graphiti 0.8.0M4 and GEF 3.7 [message #648269 is a reply to message #647887] |
Wed, 12 January 2011 08:36   |
I had another closer look into issue 1 (zoom animation with selected object)
and found that i probably mixed up my installations and targetd yesterday
It works with Graphiti 0.7.0 running against GEF 3.6, but it does not work
correctly with the head version also running against GEF 3.6. So there
indeed is a regression. Could you please open a bugzilla to track that?
The other issue I still can't reproduce using the tutorial.
Michael
> tutorial sample:
> Romain
Re: Regressions with Graphiti 0.8.0M4 and GEF 3.7 [message #648504 is a reply to message #648269] |
Thu, 13 January 2011 09:47  |
Romain Raugi Messages: 15 Registered: July 2009 |
Hello Michael,
Here is the bugzilla for the zoom animation issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=334233
Romain
Le 12/01/2011 09:36, Michael Wenz a écrit :
> Michael
> "Romain Raugi"<romain.raugi@fr.ibm.com> wrote in message
>> Hi,
>> tutorial sample:
>> Thanks,
>> Romain
FUDForum. Page generated in 0.02212 seconds
