Re: Can't start eclipse helios [message #647764 is a reply to message #647754] |
Sat, 08 January 2011 18:01 |
> I would be thankful for each idea.
My idea is that more information on your setup and the problem greatly
enhances the chance of getting a helpful answer. Try providing more
information along these topics:
- java version (to get it open a console and type "java -version")
- the exact eclipse version (which zip/tar.gz file did you download)
- how you unziped/unarchived it
- how do you run Eclipse (command line, doubleclicking, ...)
- are we talking about a plain vanilla eclipse or did you change/extend
anything (additional plugins, edit eclipse.ini, ...)
- The error message and stack trace from the .log file are essential
(move the file away, run Eclipse again --> only logs from one run in
the newly created log)
- have you tried running Eclipse from the command line? (you might want
to add the options -consoleLog -debug and -noExit to get the most
debug output about your problem)
Michael
Re: Can't start eclipse helios [message #647766 is a reply to message #647479] |
Sat, 08 January 2011 18:30 |
Florian Messages: 3 Registered: January 2011 |
Okay, I try to give you the information you need. Sry, it's the first time, that I have to seek for help in a forum like this
java version:
java version "1.6.0_22"
Java(TM) SE Runtime Environment (build 1.6.0_22-b04-307-10M3261)
Java HotSpot(TM) 64-Bit Server VM (build 17.1-b03-307, mixed mode)
eclipse version:
eclipse-java-helios-SR1-macosx-cocoa-x86_64.tar.gz
i have doubleclicked it, so it unpacked automatically (on mac)
i used winrar to unzip it and unpacked the whole thing in a folder (on windows)
I run the program by doubleclicking it
Yes, we are talking about the vanilla eclipse, it's the normal downloadable version, withput any further configurations
The error message says:
see the log file and then the path to the log file, which leads to the configurations folder.
each time I try to run it, a new log file is created, but i don't know what you mean with stack trace
no, i have not tried to run it out of the console, would i make a difference? If yes, can you tell me how to start it via the terminal?
I hope this helps you, if there are any further questions, that would help, helping me, please ask. I try to answear as quick as possible
FUDForum. Page generated in 0.03303 seconds
