Home » Modeling » EMF » Extending EMF Code Generator
Extending EMF Code Generator [message #647243] Wed, 05 January 2011 10:27 Go to next message
Stephan Zehrer is currently offline Stephan ZehrerFriend
Member
in this message Ed gives the comment to use Dynamic Templates (DT) to change the existing templates and to create a plugin and write a Generator Adapter to add new files to the generation. The new one can be overwritten again by the DT.
Well I started in my EMF Addon project to write some DT for generation of a bit more structured EMF editor.
At one point now I have to add a new file, so i wrote a plugin for it based on org.eclipse.emf.examples.generator.validator.
Now the question now is how can I overwrite existing templates in the plugin, the sample shows only adding new one.
In the other case it is always both required the plugin and the configuration in the genmodel to use the DT templates.
To simplify this i like to merge all in the plugin and e.g. enabled it by an annotation in the genmodel.
Greetings
Stephan
[Updated on: Wed, 05 January 2011 10:29]
Report message to a moderator
Re: Extending EMF Code Generator [message #647340 is a reply to message #647243] Wed, 05 January 2011 17:04 Go to previous messageGo to next message
--------------010409070401000507060309
Stephan,
Notice that the class loader of your derived generator adapter is used
to find the compiled (static) template, so if you have compiled
templates with the same qualified names as provided by EMF's generator
they'll "override" the ones from the base.
protected JETEmitter createJETEmitter(JETEmitterDescriptor
jetEmitterDescriptor)
JETEmitter jetEmitter = new JETEmitter(getTemplatePath(),
jetEmitterDescriptor.templatePathName, getClass().getClassLoader());
try
setStaticTemplateClass(jetEmitter,
jetEmitterDescriptor.className);
Stephan Zehrer wrote:
> Hello,
> in
> http://www.eclipse.org/forums/index.php?t=msg&S=26948a75 00a8f8b49cfde1a577ad810c&th=155261&goto=489160
> Well I started in my http://code.google.com/a/eclipselabs.org/p/emf/
> In the other case it is always both required the plugin the
> Greetings
> Stephan
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
<title></title>
</head>
Stephan,<br>
<br>
they'll "override" the ones from the base.<small><br>
</small>
<blockquote><small>  protected JETEmitter
createJETEmitter(JETEmitterDescriptor jetEmitterDescriptor)</small><br>
<small>  {</small><br>
<small>    JETEmitter jetEmitter = new JETEmitter(getTemplatePath(),
jetEmitterDescriptor.templatePathName, getClass().getClassLoader());</small><br>
<br>
<small>    try</small><br>
<small>      setStaticTemplateClass(jetEmitter,
jetEmitterDescriptor.className);</small><br>
</blockquote>
<br>
<blockquote cite="mid:ig1gph$u8b$1@news.eclipse.org" type="cite">Hello,
<br>
<br>
in
<a class="moz-txt-link-freetext" href=" http://www.eclipse.org/forums/index.php?t=msg&S=26948a75 00a8f8b49cfde1a577ad810c&th=155261&goto=489160">http://www.eclipse.org/forums/index.php?t=msg&amp ;S=26948a7500a8f8b49cfde1a577ad810c&amp;th=155261&am p;goto=489160 </a>
again by the DT.
<br>
<br>
Well I started in my <a class="moz-txt-link-freetext" href="http://code.google.com/a/eclipselabs.org/p/emf/">http://code.google.com/a/eclipselabs.org/p/emf/</a> to
write some DT for generation of a bit more structured EMF editor. At
<br>
<br>
plugin, the sample shows only adding new one.  <br>
<br>
<br>
<br>
Greetings
<br>
<br>
Stephan
<br>
</blockquote>
</body>
</html>
--------------010409070401000507060309--
Ed Merks
Re: Extending EMF Code Generator [message #647709 is a reply to message #647340] Fri, 07 January 2011 23:19 Go to previous messageGo to next message
Member
Hi Ed,
thx for your response ...
Ed Merks wrote on Wed, 05 January 2011 12:04
try
This sounds for me I just put the compiled temples into the plugin and it should work? ... Well tested and I does (in my case) not Smile
After that I added an generateJava call in my GenerationAdapter ... did not work either ..
Now which of both is correct or is there a third option I just not see?
Btw ... why are the NL public in your compiled temples ... is there a special setting in JET?
Greetings from Germany
Stephan
Re: Extending EMF Code Generator [message #647712 is a reply to message #647709] Fri, 07 January 2011 23:46 Go to previous messageGo to next message
--------------010401080606050307030809
Stephan,
Comments below.
> Hi Ed,
>> used to find the compiled (static) template, so if you have compiled
>> generator they'll "override" the ones from the base.
>> try
> it should work? ... Well tested and I does (in my case) not :)
All I can suggest is looking at determining why the class loader for
your derived generator adapter (hmmm, you do have one?) doesn't find
your versions of the classes. when setStaticTemplateClass is called.
try
Look into what's happening when the template class is set...
Look at JETEmitter.getObject; it's important that the template can be
specialized to generate the right type of line feeds depending on
preferences.
> Stephan
<html>
<head>
</head>
Stephan,<br>
<br>
Comments below.<br>
<br>
<br>
<blockquote cite="mid:ig86ob$2gh$1@news.eclipse.org" type="cite">Hi Ed,
<br>
<br>
thx for your response ... <br>
<br>
<blockquote type="cite">Notice that the class loader of your derived
generator adapter is used to find the compiled (static) template, so if
you have compiled templates with the same qualified names as provided
by EMF's generator they'll "override" the ones from the base.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
        try
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
your versions of the classes. when setStaticTemplateClass is called.<br>
<br>
</blockquote>
<br>
<blockquote cite="mid:ig86ob$2gh$1@news.eclipse.org" type="cite">After
work either ..   <br>
<br>
</blockquote>
Look into what's happening when the template class is set...<br>
<blockquote cite="mid:ig86ob$2gh$1@news.eclipse.org" type="cite"><br>
<br>
</blockquote>
preferences.<br>
Greetings from Germany <br>
Stephan
<br>
</blockquote>
</body>
</html>
--------------010401080606050307030809--
Ed Merks
Re: Extending EMF Code Generator [message #647741 is a reply to message #647712] Sat, 08 January 2011 14:03 Go to previous messageGo to next message
Member
Ed Merks wrote on Fri, 07 January 2011 18:46
Yes I have one, but I think I need an example to explain what I want.
I have an new template ResourceManager which is generated in my GenAdapter. (without a AdapterFactory)
Now i have adapted the Editor.javajet template to use the ResourceManager.
Just adding the editor template class to my plugin didn't work. It is still the
GenPackageGeneratorAdapter of the ecore.codegen plugin which generate the editor
and I see at the moment no way how this plugin should find my class. (correct??)
So i expect i have to do more. (e.g. registration? )
You mean in the generateEditor method?
But at this time the editor is already generated.
Where/When is it set?
The JETEmitterDescriptors is provided only in the generateJava call as far as I see.
>preferences.
Ok I'll take take a look
thanks
Stephan
Re: Extending EMF Code Generator [message #647761 is a reply to message #647741] Sat, 08 January 2011 17:08 Go to previous messageGo to next message
--------------070703050004010001020707
Stephan,
Comments below.
> ResourceManager.
> still the GenPackageGeneratorAdapter of the ecore.codegen plugin which
> generate the editor and I see at the moment no way how this plugin
I see. UML2 does this, but it has its own extended GenModel and
therefore has specialized adapters that kick in.
No, I keep pointing you to the specific class in which to set breakpoints.
> as far as I see.
I have a feeling you're not taking much advantage of the debugger.
You'll understand the behavior of a framework much better if you set a
breakpoint and then look at all the calls that lead up to a specific
point in the code. That's what I've been prompting you to do. It's
much better to look at code in a running dynamic process then to do
endless static analysis.
>> preferences.
Another technique that should work well in your type of situation is to
use a platform:/plugin/<your-bundle>/templates in the GenModel's
Template Path. That should make this code kick in to create a class
loader that loads classes, i.e., the compiled templates, from your bundle.
else if (templateURI.isPlatformPlugin())
final Bundle bundle =
Platform.getBundle(templateURI.segment(1));
if (bundle != null)
// Define a class loader that will look up the class
in the bundle,
// and if it doesn't find it there, will look in the
parent.
theClassLoader =
new URLClassLoader(new URL [0], jetEmitter.classLoader)
public Class<?> loadClass(String className) throws
ClassNotFoundException
try
return bundle.loadClass(className);
catch (ClassNotFoundException
classNotFoundException)
return super.loadClass(className);
> thanks
> Stephan
<html>
<head>
</head>
Stephan,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:ig9qh8$amu$1@news.eclipse.org" type="cite">Ed
<br>
<blockquote type="cite">All I can suggest is looking at determining
why the class loader for your derived generator adapter (hmmm, you do
have one?) doesn't find your versions of the classes. when
<br>
</blockquote>
<br>
<br>
<br>
<br>
ResourceManager.
<br>
<br>
<br>
<br>
</blockquote>
therefore has specialized adapters that kick in.  <br>
<blockquote cite="mid:ig9qh8$amu$1@news.eclipse.org" type="cite"><br>
<blockquote type="cite">Now which of both is correct or is there a
<br>
</blockquote>
<br>
</blockquote>
You mean in the generateEditor method?</blockquote>
breakpoints.<br>
<blockquote cite="mid:ig9qh8$amu$1@news.eclipse.org" type="cite"> But
<br>
<br>
far as I see.
<br>
</blockquote>
endless static analysis.<br>
<br>
<blockquote type="cite">Btw ... why are the NL public in your
<br>
</blockquote>
preferences.
<br>
</blockquote>
<br>
</blockquote>
use a platform:/plugin/&lt;your-bundle&gt;/templates in the GenModel's
bundle.<br>
<small><br>
</small>
<blockquote><small>          else if (templateURI.isPlatformPlugin())</small><br>
<small>            final Bundle bundle =
Platform.getBundle(templateURI.segment(1));</small><br>
<small>            if (bundle != null)</small><br>
<small>              // Define a class loader that will look up the
class in the bundle,</small><br>
<small>              // and if it doesn't find it there, will look in
the parent.</small><br>
<small>              //</small><br>
<small>              theClassLoader = </small><br>
<small>                new URLClassLoader(new URL [0],
jetEmitter.classLoader)</small><br>
<small>                  @Override</small><br>
<small>                  public Class&lt;?&gt; loadClass(String
className) throws ClassNotFoundException</small><br>
<small>                      return bundle.loadClass(className);</small><br>
<small>                    }</small><br>
<small>                    catch (ClassNotFoundException
classNotFoundException)</small><br>
<small>                      return super.loadClass(className);</small><br>
<small>                };</small><br>
</blockquote>
<br>
thanks
<br>
<br>
Stephan
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------070703050004010001020707--
Ed Merks
Re: Extending EMF Code Generator [message #647773 is a reply to message #647761] Sat, 08 January 2011 20:24 Go to previous messageGo to next message
Member
Hi Ed,
[quote title=Ed Merks wrote on Sat, 08 January 2011 12:08c
[/quote]
I guess this is a yes ...
Well I did ... already on your last mail.
I put it on "setStaticTemplateClass"
And it get called for each template which is generated. (e.g. staring with ....templates.editor.Plugin if you generate the Editor".
In the line "Class<?> templateClass = getClass().getClassLoader().loadClass(className);" the classloader of getClass is used.
But getClass return, in the case of the Edior.javajet template (which i like replace), the class .... genmodel.generator.GenPackageGeneratorAdapter of the ecore plugin. That is the first time where the editor is generated.
So I see no change that in the first step he will ever find my template class because the plugin is always using the class loader of the generator adapter.
The second time it is called in my generator adapter now but it seems, even it uses the classloader of my gen adapter, it loads the wrong class.
I guess because the class is already loaded from the first time?
I will try it now with an other template name.
But the behavior of the first generation i can not change, or is there a mistake in my conclusion?
> as far as I see.
Well I did ... hope your feeling changed now Smile
if (bundle != null)
in the bundle,
parent.
theClassLoader =
try
Ok that's maybe a solution, i can use it even as general switch for all generation task in the plugin.
The disadvantage of this, i can not use dynamicTemplates any more for development.
It is very time consuming always redeploy the plugin for testing. Mmm i have to think about this Smile
Thanks..
Stephan
[Updated on: Sat, 08 January 2011 20:25]
Re: Extending EMF Code Generator [message #647778 is a reply to message #647773] Sat, 08 January 2011 21:41 Go to previous messageGo to next message
Stephan,
You could switch from platform:/plugin to platform:/resource while
developing. Note that even with platform:/resource, if your project has
a JETNature and hence has compiled templates that the JETEmitter should
end up using those compiled versions...
> Hi Ed,
>> which generate the editor and I see at the moment no way how this
> therefore has specialized adapters that kick in. [/quote]
> Quote:
>> breakpoints.
> Well I did ... already on your last mail. I put it on
> getClass is used.
> I will try it now with an other template name. But the behavior of the
> conclusion?
> Quote:
>> call > as far as I see.
>> a breakpoint and then look at all the calls that lead up to a
>> specific point in the code. That's what I've been prompting you to
>> do. It's much better to look at code in a running dynamic process
>> then to do endless static analysis.
> Well I did ... hope your feeling changed now :)
> Quote:
>> to use a platform:/plugin/<your-bundle>/templates in the GenModel's
>> bundle.
>> if (bundle != null)
>> in the bundle,
>> parent.
>> theClassLoader =
>> @Override
>> try
> development. It is very time consuming always redeploy the plugin for
> testing. Mmm i have to think about this :)
> Thanks..
> Stephan
Ed Merks
Re: Extending EMF Code Generator [message #647840 is a reply to message #647778] Sun, 09 January 2011 21:14 Go to previous messageGo to next message
Member
Ed,
Thanks !!
Ed Merks wrote on Sat, 08 January 2011 16:41
I debugged now some hours to understand what JETEmitter is doing and why it does not work in my configuration.
But at the end I can say the solution with adding platform:/plugin/<plugin-id>/templates works!
I am not sure it is a bug, but it was very helpful to removed the .JETEmitter project from the workspace.
In an clean environment where no compiled version's of old JET Templates and Template classes exist somewhere It do what it should.
Btw. the NL field is not public if you use the M2T Jet project configuration in JET1 mode, i opened a bug for this.
I collected some "hint" related to this topic on this page http://wiki.eclipse.org/EMF/ExtendingCodeGeneration
I hope this will help other people if they have similar problems.
Greetings
Stephan
Re: Extending EMF Code Generator [message #647857 is a reply to message #647778] Mon, 10 January 2011 07:40 Go to previous messageGo to next message
Member
[Updated on: Mon, 10 January 2011 07:42]
Re: Extending EMF Code Generator [message #647957 is a reply to message #647857] Mon, 10 January 2011 15:26 Go to previous message
--------------080701060707000208060801
Stephan,
Thanks for sharing your experience in the wiki!! Likely more folks
would find it from the EMF Recipes page:
http://wiki.eclipse.org/EMF/Recipes
> Ed,
> Thanks !!
>> has a JETNature and hence has compiled templates that the JETEmitter
>> should end up using those compiled versions...
> After a hour debugging I understand now more or less what the
> JETEmitter is doing :)
> And I can confirm that the platform:/plugin method works. My problems
> were solved after the removing of the .JETEmitter project from my test
> environment workspace, without it always found old version's of the
> classes (maybe a bug? .... if so it will happen again I will open one)
> Nevertheless it works now !
> Btw. the NL problem was produced if you use M2T JET project in JET1
> mode :) and not the EMF version.
> I put some may experiences on the following wiki page
> Greetings
> Stephan
<html>
<head>
</head>
Stephan,<br>
<br>
would find it from the EMF Recipes page:<br>
<blockquote><a href="http://wiki.eclipse.org/EMF/Recipes">http://wiki.eclipse.org/EMF/Recipes</a><br>
</blockquote>
<br>
<blockquote cite="mid:igecs2$s3b$1@news.eclipse.org" type="cite">Ed,
<br>
<br>
Thanks !!
<br>
<br>
<br>
<blockquote type="cite">You could switch from platform:/plugin to
platform:/resource while developing.  Note that even with
platform:/resource, if your project has a JETNature and hence has
compiled templates that the JETEmitter should end up using those
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/EMF/ExtendingCodeGeneration">http://wiki.eclipse.org/EMF/ExtendingCodeGeneration</a>
<br>
<br>
Greetings
<br>
<br>
Stephan <br>
<br>
</blockquote>
</body>
</html>
--------------080701060707000208060801--
Ed Merks
Previous Topic:Source for EMF Common (2.6.0.v20100914-1218)
Next Topic:[CDO] How to configure cdo-server.xml to use H2
Current Time: Wed Dec 02 04:11:50 GMT 2020
Powered by FUDForum. Page generated in 0.03044 seconds
