Problem in running multiple swtbot in thread [message #647039] |
Tue, 04 January 2011 09:22 |
vaibhav Messages: 22 Registered: September 2010 |
I am trying to run following code snippet in a single thread.Then "first swtbot" snippet works fine means java project with name MyFirstProject got created, but "second swtbot" throw some exception which i mentioned at last:
Runnable runnable = new Runnable() {
public void run() {
SWTWorkbenchBot bot=new SWTWorkbenchBot();
*first swtbot
bot.menu("File").menu("New").menu("Project...").click();
SWTBotShell shell = bot.shell("New Project");
shell.activate();
bot.tree().expandNode("Java").select("Java Project");
bot.button("Next >").click();
bot.textWithLabel("Project name:").setText("MyFirstProject");
bot.button("Finish").click();
*second swtbot
bot.menu("File").menu("New").menu("File").click();
SWTBotShell shell1 = bot.shell("New File");
shell1.activate();
bot.textWithLabel("File name:").setText("MyFile");
bot.button("Finish").click(); }
new Thread(runnable, "Executing thread...").start(); //$NON-NLS-1$
}[/B]
The Exception is
!ENTRY org.eclipse.ui 4 0 2011-01-04 14:30:01.245
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.swt.SWTException: Widget is disposed)
at org.eclipse.swt.SWT.error(SWT.java:4083)
at org.eclipse.swt.SWT.error(SWT.java:3998)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:137)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2427)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:663)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Caused by: org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:3969)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:340)
at org.eclipse.swt.widgets.Decorations.getMenuBar(Decorations.java:672)
at org.eclipse.swtbot.swt.finder.finders.MenuFinder$1.run(MenuFinder.java:106)
at org.eclipse.swtbot.swt.finder.finders.MenuFinder$1.run(MenuFinder.java:1)
at org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable$2.doRun(UIThreadRunnable.java:140)
at org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable$1.run(UIThreadRunnable.java:89)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
... 23 more
org.eclipse.swtbot.swt.finder.exceptions.WidgetNotFoundException: Could not find widget.
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntilWidgetAppears(SWTBotFactory.java:348)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.menu(SWTBotFactory.java:257)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.menu(SWTBotFactory.java:208)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.menu(SWTBotFactory.java:198)
at com.sap.departmentdsl.providers.swtbot.MenuImpl.select(MenuImpl.java:26)
at com.sap.departmentdsl.core.impl.SelectMenuImpl.execute(SelectMenuImpl.java:166)
at com.sap.departmentdsl.core.impl.TestImpl.execute(TestImpl.java:313)
at com.sap.companydsl.ui.action.Executable$1.run(Executable.java:35)
Caused by: org.eclipse.swtbot.swt.finder.widgets.TimeoutException: Timeout after: 5000 ms.: Could not find a menu within the shell 'Shell with text {}' matching 'with mnemonic 'File''
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBotFactory.java:398)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBotFactory.java:372)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBotFactory.java:360)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntilWidgetAppears(SWTBotFactory.java:346)
... 8 more
Exception in thread "Executing test..." org.eclipse.swtbot.swt.finder.exceptions.WidgetNotFoundException: Could not find widget.
at org.eclipse.swtbot.swt.finder.SWTBotFactory.shells(SWTBotFactory.java:112)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.shell(SWTBotFactory.java:102)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.shell(SWTBotFactory.java:93)
at com.sap.departmentdsl.providers.swtbot.WizardImpl.open(WizardImpl.java:11)
at com.sap.departmentdsl.core.impl.WizardStepImpl.execute(WizardStepImpl.java:180)
Caused by: org.eclipse.swtbot.swt.finder.widgets.TimeoutException: Timeout after: 5000 ms.: Could not find shell matching: with text 'New File'
... 8 more
Has anyone help me out how we can able to run this?
Thanks in advance,
Best Regards,
Vaibhav
[Updated on: Tue, 04 January 2011 15:27] Report message to a moderator
Re: Problem in running multiple swtbot in thread [message #647348 is a reply to message #647039] |
Wed, 05 January 2011 17:58 |
Ketan Padegaonkar Messages: 873 Registered: July 2009 |
Hi Vaibhav,
When you click finish on the new project dialog, that dialog might take
a few milliseconds to close.
The next line after clicking on finish looks for the "File" menu, but
cannot find it because the new project dialog is still the active dialog.
Try using
bot.waitUntil(Condions.shellCloses(newProjectDialog))
after clicking on the finish button to see if this fixes your problem.
Ketan
ketan.padegaonkar.name | eclipse.org/swtbot | @ketanpkr
On 1/4/11 1:22 AM, vaibhav wrote:
> at last:
> public void run() {
> *first swtbot
> shell.activate();
> *second swtbot
> shell1.activate();
> }[/B]
> The Exception is
> !STACK 0
> at
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:137)
> at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:4041)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3660)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2629)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
> at org.eclipse.swt.widgets.Decorations.getMenuBar(Decorations.j ava:672)
> at
> org.eclipse.swtbot.swt.finder.finders.MenuFinder$1.run(MenuF inder.java:106)
> at
> org.eclipse.swtbot.swt.finder.finders.MenuFinder$1.run(MenuF inder.java:1)
> at
> org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable$2.doR un(UIThreadRunnable.java:140)
> at
> org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable$1.run (UIThreadRunnable.java:89)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> at
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
> ... 23 more
> org.eclipse.swtbot.swt.finder.exceptions.WidgetNotFoundExcep tion: Could
> not find widget.
> at
> org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntilWidgetA ppears(SWTBotFactory.java:348)
> at org.eclipse.swtbot.swt.finder.SWTBotFactory.menu(SWTBotFacto ry.java:257)
> at org.eclipse.swtbot.swt.finder.SWTBotFactory.menu(SWTBotFacto ry.java:208)
> at org.eclipse.swtbot.swt.finder.SWTBotFactory.menu(SWTBotFacto ry.java:198)
> at com.sap.testdsl.providers.swtbot.MenuImpl.select(MenuImpl.ja va:26)
> at
> com.sap.testdsl.core.impl.SelectMenuImpl.execute(SelectMenuI mpl.java:166)
> at com.sap.testdsl.core.impl.TestImpl.execute(TestImpl.java:313 )
> at com.sap.storydsl.ui.action.Executable$1.run(Executable.java: 35)
> at
> org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBot Factory.java:398)
> at
> org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBot Factory.java:372)
> at
> org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBot Factory.java:360)
> at
> org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntilWidgetA ppears(SWTBotFactory.java:346)
> ... 8 more
> not find widget.
> at
> at
> org.eclipse.swtbot.swt.finder.SWTBotFactory.shells(SWTBotFac tory.java:112)
> at
> org.eclipse.swtbot.swt.finder.SWTBotFactory.shell(SWTBotFact ory.java:102)
> at org.eclipse.swtbot.swt.finder.SWTBotFactory.shell(SWTBotFact ory.java:93)
> at com.sap.testdsl.providers.swtbot.WizardImpl.open(WizardImpl. java:11)
> at
> com.sap.testdsl.core.impl.WizardStepImpl.execute(WizardStepI mpl.java:180)
> File'
> at
> at
> at
> at
> ... 8 more
> Thanks in advance,
> Best Regards,
> Vaibhav
FUDForum. Page generated in 0.02093 seconds
