Home » Modeling » EMF » [EMF compare] ExampleLauncher problem
[EMF compare] ExampleLauncher problem [message #646621] |
Wed, 29 December 2010 11:56 |
No real name Messages: 42 Registered: December 2010 |
Member |
HELP
that dosn't work
code :
final EObject model1 = ModelUtils.load(new File(" C:\\pfe\\runtime-EclipseApplication(1)\\LibraryTest\\My1.lib rary "), resourceSet1);
Loading resources.
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Class 'Library' is not found or is abstract. (file:/C:/pfe/runtime-EclipseApplication(1)/LibraryTest/My1. library, 2, 19)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLL oadImpl.java:83)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:191)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
at org.eclipse.emf.compare.util.ModelUtils.load(ModelUtils.java :381)
at org.eclipse.emf.compare.util.ModelUtils.load(ModelUtils.java :278)
at org.eclipse.example.library.Test.main(Test.java:92)
Caused by: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'Library' is not found or is abstract. (file:/C:/pfe/runtime-EclipseApplication(1)/LibraryTest/My1. library, 2, 19)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObje ctFromFactory(XMLHandler.java:2244)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObje ctFromFactory(XMLHandler.java:2235)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1332)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1468)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:83)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:169)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator. startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$ContentDispatcher.scanRootElementHook(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
... 6 more
[Updated on: Thu, 30 December 2010 08:41] Report message to a moderator
Re: [EMF compare] ExampleLauncher problem [message #646892 is a reply to message #646621] |
Sun, 02 January 2011 17:26 |
Philip Langer Messages: 31 Registered: July 2009 |
Member |
this is not an EMF Compare specific problem! It's general handling of
EMF models.
The exception indicates that you are loading an instance of a metamodel
that has not been registered yet. The metamodel package with the
specified URI "...example.eclipse.org/Library" has to be registered
before loading its instances.
That means, you must have the plug-in installed that specifies the
Library metamodel Package and its generated model code. This plug-in
should also extend the "generated_packages" extension point in order to
get its metamodel package automatically registered.
You can also register it manually before loading its instances by
calling its EPackage instance using something like:
<code>
LibraryPackage.eINSTANCE;
</code>
Of course, the LibraryPackage class must be in your build-path (e.g.,
plug-in dependency) to do so.
Hope that helps!
Philip
On 2010-12-29 12:56, ST wrote:
> HELP that dosn't work code :
> resourceSet1);
> org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Package with
> uri 'http://www.example.eclipse.org/Library' not found.
> 73)
> oadImpl.java:83)
> java:191)
> ourceImpl.java:180)
> ceImpl.java:1494)
> ceImpl.java:1282)
> Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package
> with uri 'http://www.example.eclipse.org/Library' not found.
> 73)
> at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X
> MLHandler.java:2591)
> at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi
> x(XMLHandler.java:2422)
> (XMLHandler.java:1299)
> LHandler.java:1468)
> Handler.java:1019)
> Handler.java:83)
> ndler.java:1001)
> ndler.java:712)
> ndler.java:169)
> nknown Source)
> java:181)
> ... 6 more
Re: [EMF compare] ExampleLauncher problem [message #990218 is a reply to message #646935] |
Tue, 11 December 2012 13:19 |
Greg L Messages: 9 Registered: November 2012 |
Can you provide some more detailed solution to the problem you had?
I am trying to perform HOT ATL transformations, and I have the following similar error when trying to load a resource content from the InputStream (result of a model transformation):
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Class 'Module' is not found or is abstract. (file:///C:/Users/XX/workspace/myFile.xmi, 3, 59)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLLoadImpl.java:83)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:191)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:242)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1511)
at fr.tpt.atl.hot.launcher.EModelCopyBackup.saveModels(EModelCopyBackup.java:257)
at fr.tpt.atl.hot.launcher.EModelCopyBackup.main(EModelCopyBackup.java:108)
Caused by: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'Module' is not found or is abstract. (file://myClass.xmi, 3, 59)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObjectFromFactory(XMLHandler.java:2244)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObjectFromFactory(XMLHandler.java:2235)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1332)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1468)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1019)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:87)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:169)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:181)
... 4 more
I run this in a standalone application, so I tried to register my metamodel manually before I will create an instance of it, in the following way:
resourceSet.getPackageRegistry().put("http://www.eclipse.org/gmt/2005/ATL", EcorePackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XMIResourceFactoryImpl());
Am I missing something? Can you provide some more details on how did you solve the problem?
Thank you in advance.
Greg
Re: [EMF compare] ExampleLauncher problem [message #990225 is a reply to message #990218] |
Tue, 11 December 2012 13:38 |
Ed Merks Messages: 33136 Registered: July 2009 |
Greg,
What model does the class "Module" come from? Have you tried
registering that model, i.e.,
resourceSet.getPackageRegistry().put(XyxPackage.eNS_URI,
XyzPackage.eINSTANCE);
On 11/12/2012 2:19 PM, Greg L wrote:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> ... 4 more
> following way:
> Greg
Ed Merks
Re: [EMF compare] ExampleLauncher problem [message #1214609 is a reply to message #1214524] |
Wed, 27 November 2013 19:32 |
If this question is about bpmn, it's best use their specific
newsgroup. Perhaps they provide a specialized resource implementation
(and associated resource factory) that you need to use...
On 27/11/2013 7:44 PM, Tarcísio Couto wrote:
> Hello guys, I have a similiar problem, when a try to load a model in
> my tool, the following error happen:
> !MESSAGE org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class
> 'definitions' is not found or is abstract.
> (file:/C:/Users/tcp/reference_process.bpmn, 2, 423)
> !STACK 0
> I don't know how to solve this problem, and if there is a code for
> this, I don't know what the code is and where to put it.
Ed Merks
Re: [EMF compare] ExampleLauncher problem [message #1790426 is a reply to message #1215660] |
Sun, 10 June 2018 15:12 |
Cristina Redriguez Messages: 10 Registered: February 2017 |
Hi there,
I am trying to run ATL program using a java program, have the following error when trying to run my program java. It is noted that the BPMN.ecore is loaded from a plugin registered in eclipse. The following error is generated:
org.eclipse.m2m.atl.core.ATLCoreException: Error loading Models\process_1.bpmn: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'definitions' is not found or is abstract. (file:///x/Models/process_1.bpmn, 2, 370)
at org.eclipse.m2m.atl.core.emf.EMFInjector.inject(EMFInjector.java:70)
at org.eclipse.m2m.atl.core.emf.EMFInjector.inject(EMFInjector.java:84)
at comp.BPMN2BPMNSUC.loadModels(BPMN2BPMNSUC.java:122)
at comp.BPMN2BPMNSUC.main(BPMN2BPMNSUC.java:79)
Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'definitions' is not found or is abstract. (file:///D:/memoirethese/pratique/JavaBPMN2BPMNSUC/tran/Models/process_1.bpmn, 2, 370)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.m2m.atl.core.emf.EMFInjector.inject(EMFInjector.java:65)
... 3 more
Caused by: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'definitions' is not found or is abstract. (file:///D:/memoirethese/pratique/JavaBPMN2BPMNSUC/tran/Models/process_1.bpmn, 2, 370)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObjectFromFactory(XMLHandler.java:2251)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObjectFromFactory(XMLHandler.java:2242)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1339)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1475)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1026)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:77)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:163)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl$NSContentDriver.scanRootElementHook(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:253)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 5 more
. Someone help me please
Thanks in advance !
BOUZIDI
[Updated on: Sun, 10 June 2018 15:23] Report message to a moderator
Current Time: Fri Apr 19 00:15:51 GMT 2024
Powered by FUDForum. Page generated in 0.02561 seconds
