Re: validation of a file with a new extension "myxml" [message #648872 is a reply to message #646474] |
Fri, 14 January 2011 19:08 |
On 12/24/2010 12:15 PM, Alain wrote:
> I juste don't knwo why the validation dosn't work at all!
> may be it's because my editor file extension is myxml?
> any ideas?
> thank you
Source Validation isn't an inherited behavior in quite the same way that
the viewer configuration is: if you define any source validator
specifically for your content type, no source validators are inherited
from its base types. In your case it means that the normal XML source
validation will not be used on your content type unless you recontribute
it as your own extension to your content type specifically. This
strategy was chosen to help deal with XSL files, where an XSL-specific
validator could work properly but a normal XML validation would report a
number of problems.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.03483 seconds
