Home » Language IDEs » PHP Development Tools (PDT) » Setting.(how to set stuff.)
icon2.gif  Setting. [message #645603] Sat, 18 December 2010 16:08 Go to next message
Mor  is currently offline Mor Friend
Hello , I'm using the PHP editor and I have few question about it's setting.
first question is colors , the colors the code get.
for example text get color X
and 'For' loop get the color Y
and the '<?php ?>' php starting script get the color Z.
How I can change the color each syntax get?
second question is how I can set auto save to UTF8 without BOM as default save.
The editor I'm using is from here
An other question is:
First Ive install it it has auto open to me , now after I've closed it I can't find how to open the program
no file marking , not any shortcut , nothing , even no a directory with the name of the editor , just directory of 'workbench' without any file to open the editor , so , where i can find the exe file and open the editor?
Thanks.
[Updated on: Sat, 18 December 2010 16:35]
Report message to a moderator
Re: Setting. [message #645609 is a reply to message #645603] Sat, 18 December 2010 18:33 Go to previous messageGo to next message
I've got answer to all of the question except the syntax coloring.
Re: Setting. [message #645611 is a reply to message #645603] Sat, 18 December 2010 19:18 Go to previous messageGo to next message
Since I can't edit , I got to say ,
All got solved except the saving part ,
I want the editor to save automatically with UTF8 no BOM.
Re: Setting. [message #647668 is a reply to message #645603] Fri, 07 January 2011 16:52 Go to previous message
paulfrottawa is currently offline paulfrottawaFriend
I'm about two weeks into Eclipse but think I can help you. R click the project and select properties then select resources and other for Text file encoding and use the drop down list for utf-8
[Updated on: Fri, 07 January 2011 16:53]
Previous Topic:Content Assist for Files Outside the project.
Next Topic:Editor removes tabs before brace
Current Time: Tue Oct 15 00:41:14 GMT 2024
Powered by FUDForum. Page generated in 0.04005 seconds
