Home » Archived » M2M (model-to-model transformation) » [ATL] asSequence(): RegularVM vs EMF-VM
icon5.gif  [ATL] asSequence(): RegularVM vs EMF-VM [message #645538] Fri, 17 December 2010 17:42 Go to next message
Alvaro Jimenez Rielo is currently offline Alvaro Jimenez RieloFriend
Member
I have this code:
self.source.asSequence()->first().oclIsUndefined()
for different Metaclasses that its 'source' attribute is 1..1 or 1..N (It depends on the metaclass). Using "asSequence()" in RegularVM, the code works for all metaclasses. But in EMF-VM, I receive this error:
org.eclipse.m2m.atl.engine.emfvm.VMException: Operation not found: IN!Member.asSequence()
because 'source' attribute in Member Metaclass is 1..1.
so, my question is: are there any possibility to convert 'source' to a collection type using EMF-VM?
Thanks for advance,
Alvaro.
[Updated on: Fri, 17 December 2010 17:43]
Report message to a moderator
Re: [ATL] asSequence(): RegularVM vs EMF-VM [message #645924 is a reply to message #645538] Tue, 21 December 2010 08:38 Go to previous messageGo to next message
Vincent MAHE is currently offline Vincent MAHEFriend
Le 17/12/2010 18:42, ajimenezr a écrit :
> Hello,
> I have this code:
> self.source.asSequence()->first().oclIsUndefined() for different
> IN!Member.asSequence() because 'source' attribute in Member Metaclass is
> 1..1.
Some "facilities" of the old VM were more bugs than features. The recent
one is more strict so it needs to expurge old "lazy" code which was
relying on these holes in the checker.
In your case, I recommend you test the status of the 'source' attribute
in an 'if' structure, which will also document better your transformation.
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: [ATL] asSequence(): RegularVM vs EMF-VM [message #646937 is a reply to message #645538] Mon, 03 January 2011 09:54 Go to previous message
Sylvain EVEILLARD is currently offline Sylvain EVEILLARDFriend
or you can do :
Sequence{self.source}->flatten()->first().oclIsUndefined()
Previous Topic:MOF to EMF using ATL
Next Topic:[ATL] CDO model as an input
Current Time: Sun Jul 12 00:26:36 GMT 2020
Powered by FUDForum. Page generated in 0.02002 seconds
