why during my unload crossreferencer resolve my already unloaded resources .... ? [message #645415] |
Fri, 17 December 2010 08:07 |
Tristan Faure Messages: 460 Registered: July 2009 |
Hi UML2 and EMF.
I have a resourceset with UML2 resources and own resources linked to my
UML resources.
I do the "typical" unload at the end of my process to empty my resource
set and empty the UML2 CacheAdapter (in fact the InverseCrossReferencer
of the cache adapter).
for (Iterator<Resource> i = set.getResources().iterator() ; i.hasNext() ; )
Resource r = i.next() ;
r.unload();
i.remove();
The problem is when I unload a resource I can notice this stack trace
org.topcased.modeler.diagrams.model.util.DiagramsResourceImp l(org.eclipse.emf.ecore.resource.impl.ResourceImpl).load(jav a.io.InputStream,
java.util.Map<?,?>) line: 1514
org.topcased.modeler.diagrams.model.util.DiagramsResourceImp l(org.eclipse.emf.ecore.resource.impl.ResourceImpl).load(jav a.util.Map <?,?>)
line: 1282
org.topcased.modeler.editor.TopcasedAdapterFactoryEditingDom ain$TopcasedAdapterFactoryEditingDomainResourceSet(org.eclip se.emf.ecore.resource.impl.ResourceSetImpl).demandLoad(org.e clipse.emf.ecore.resource.Resource)
line: 255
org.topcased.modeler.editor.TopcasedAdapterFactoryEditingDom ain$TopcasedAdapterFactoryEditingDomainResourceSet(org.eclip se.emf.ecore.resource.impl.ResourceSetImpl).demandLoadHelper (org.eclipse.emf.ecore.resource.Resource)
line: 270
org.topcased.modeler.editor.TopcasedAdapterFactoryEditingDom ain$TopcasedAdapterFactoryEditingDomainResourceSet(org.eclip se.emf.ecore.resource.impl.ResourceSetImpl).getResource(org. eclipse.emf.common.util.URI,
boolean) line: 397
org.topcased.modeler.editor.TopcasedAdapterFactoryEditingDom ain$TopcasedAdapterFactoryEditingDomainResourceSet.getResour ce(org.eclipse.emf.common.util.URI,
boolean) line: 482
org.topcased.modeler.editor.TopcasedAdapterFactoryEditingDom ain$TopcasedAdapterFactoryEditingDomainResourceSet(org.eclip se.emf.ecore.resource.impl.ResourceSetImpl).getEObject(org.e clipse.emf.common.util.URI,
boolean) line: 216
org.eclipse.emf.ecore.util.EcoreUtil.resolve(org.eclipse.emf .ecore.EObject,
org.eclipse.emf.ecore.resource.ResourceSet) line: 202
org.eclipse.emf.ecore.EObject) line: 262
org.topcased.modeler.diagrams.model.internal.impl.DiagramsIm pl(org.eclipse.emf.ecore.impl.BasicEObjectImpl).eResolveProx y(org.eclipse.emf.ecore.InternalEObject)
line: 1483
org.eclipse.emf.ecore.util.EObjectContainmentWithInverseELis t$Resolving <E>(org.eclipse.emf.ecore.util.EcoreEList<E>).resolveProxy(org.eclipse.emf.ecore.EObject)
line: 212
org.eclipse.emf.ecore.util.EObjectContainmentWithInverseELis t$Resolving <E>(org.eclipse.emf.ecore.util.EcoreEList<E>).resolve(int,
org.eclipse.emf.ecore.EObject) line: 167
org.eclipse.emf.ecore.util.EObjectContainmentWithInverseELis t$Resolving <E>.resolve(int,
E) line: 111
org.eclipse.emf.ecore.util.EObjectContainmentWithInverseELis t$Resolving <E>(org.eclipse.emf.common.util.BasicEList<E>).get(int)
line: 354
org.eclipse.emf.ecore.util.EContentsEList$ResolvingFeatureIt eratorImpl <E> (org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorIm pl <E>).hasNext()
line: 484
org.eclipse.emf.ecore.util.EContentsEList$ResolvingFeatureIt eratorImpl <E> (org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorIm pl <E>).next()
line: 565
org.topcased.modeler.diagrams.model.util.CrossReferenceAdapt er(org.eclipse.emf.ecore.util.ECrossReferenceAdapter).unsetT arget(org.eclipse.emf.ecore.EObject)
line: 780
org.topcased.modeler.diagrams.model.util.CrossReferenceAdapt er(org.eclipse.emf.ecore.util.ECrossReferenceAdapter).unsetT arget(org.eclipse.emf.common.notify.Notifier)
line: 747
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList <E>.didRemove(int,
E) line: 156
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList <E>(org.eclipse.emf.common.util.BasicEList<E>).remove(int)
line: 622
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList <E>.remove(int)
line: 227
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList <E>(org.eclipse.emf.common.util.AbstractEList<E>).remove(java.lang.Object)
line: 466
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList <E>.remove(java.lang.Object)
line: 220
org.topcased.modeler.diagrams.model.util.CrossReferenceAdapt er(org.eclipse.emf.ecore.util.ECrossReferenceAdapter).remove Adapter(org.eclipse.emf.common.notify.Notifier)
line: 828
line: 784
line: 747
E) line: 156
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList <E>(org.eclipse.emf.common.util.AbstractEList<E>).didClear(int,
java.lang.Object[]) line: 172
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList <E>(org.eclipse.emf.common.util.BasicEList<E>).clear()
line: 646
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList <E>.clear()
line: 241
org.topcased.modeler.diagrams.model.util.DiagramsResourceImp l(org.eclipse.emf.ecore.resource.impl.ResourceImpl).unloaded (org.eclipse.emf.ecore.InternalEObject)
line: 1565
org.topcased.modeler.diagrams.model.util.DiagramsResourceImp l(org.eclipse.emf.ecore.resource.impl.ResourceImpl).doUnload ()
line: 1624
org.topcased.modeler.diagrams.model.util.DiagramsResourceImp l(org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl).doUnload()
line: 506
org.topcased.modeler.diagrams.model.util.DiagramsResourceImp l(org.eclipse.emf.ecore.resource.impl.ResourceImpl).unload()
line: 1639
The problem comes from an adapter list of the resource which is cleared
and this list triggers adapter mechanisms which will resolve elements
which will load a resource unloaded which will fill again the
CacheAdapter and creates a memory leak in my application.
How can I avoid this kind of solutions? My goal is having only proxies
after my unload process and with this behavior, it never happens.
FUDForum. Page generated in 0.02163 seconds
