White page after redirection [message #645386] |
Thu, 16 December 2010 22:46 |
Henzler Peter Messages: 19 Registered: July 2009 |
On startup RAP only displays a white page although the full source is there.
I have encountered this problem on two occations so far:
The first time when I did secure the url of to the rap application behind sping security filter.
In that case Spring takes me to the login form and after successfull authentication Spring takes me to the originally entered webaddress of my rap application. But instead the rap application I see the white page.
The second time was when I installed a proxy servlet that handled all calls to <ipaddress>:80/rap/examples and gave back the contents it got from calling <ipaddress>:8081/rap/example .
We wanted to do this because of the cross site scripting problem.
In this case I get a white page too.
As far as I understand RAP is sending an initial page to the client to find out if it is capable of displaying RAP and initiating the data communication with the RAP server.
This seems only to work with the original request to display RAP. It seems not to work, if there is some processing between.
Can anyone tell me what's the actual problem here and if there is a work around to overcome this problem?
Thank you.
Best regards
Peter Henzler
FUDForum. Page generated in 0.02005 seconds
