Home » Eclipse Projects » Eclipse Platform » Get a command id from within a handler?
Get a command id from within a handler? [message #645197] Wed, 15 December 2010 21:42 Go to next message
Stefan Ruzitschka is currently offline Stefan RuzitschkaFriend
Hi Folks,
we use the command id plus a suffix for the translation of our GUI.
For example:
commandId = "com.company.package.commands.mycommand"
suffix1 = ".label"
suffix2 = ".tooltip"
So we concatenate the commandId and several suffixes to get an unique translationId.
The handler implements IElementUpdater and extends AbstractHandler
The idea is to get the commandId from within a handler to set the text to an UIElement in the updateElement method.
For example:
String commandId = commandIdGettingMechanism(this);
String tooltipText = translationMechanism(commandId + suffix1);
element.setTooltip(tooltipText);
The question now is:
Is there a way to do it?
Is a registry of all handlers with their commands a good way to implement this? Any ideas?
Greetings
Stefan R.
Re: Get a command id from within a handler? [message #645223 is a reply to message #645197] Thu, 16 December 2010 05:13 Go to previous messageGo to next message
Prakash G.R. is currently offline Prakash G.R.Friend
You can get the command from the ExecutionEvent passed as a parameter
to the handler.execute() method
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Re: Get a command id from within a handler? [message #645244 is a reply to message #645197] Thu, 16 December 2010 08:48 Go to previous messageGo to next message
Hmm yeah I know, but the problem is, that the handler.execute() method is called, when you fire the command and normally it's done by an user interaction. I want to decorate the UIElement before the command is fired...
Re: Get a command id from within a handler? [message #645352 is a reply to message #645244] Thu, 16 December 2010 17:16 Go to previous message
> fired...
May be this would work. Make your handler implement
IExecutableExtension and in the plugin.xml when you declare the handler,
pass on the command id as the data.
- Prakash
Previous Topic:Embarrassingly basic Eclipse-on-Mac q
Next Topic:Exception while performing file search
Current Time: Thu Mar 04 19:42:47 GMT 2021
Powered by FUDForum. Page generated in 0.02095 seconds
