Home » Eclipse Projects » Remote Application Platform (RAP) » Tree H_SCROLL and Images(Issues with Tree widget in RAP 1.4 (H_SCROLL, Item Icons))
Tree H_SCROLL and Images [message #645054] Wed, 15 December 2010 12:04 Go to next message
Tiber Sept is currently offline Tiber SeptFriend
Member
Hello RAP community,
we moved a project from RAP 1.3.0 (2010-06-15) to RAP 1.4 M3 yesterday and we have two issues with the new Tree widget.
  • Issue 1 (H_SCROLL): The width of the item text generally exceeds the width of the tree client area. The horizontal scroll bar
    is displayed but it never becomes active. The SWT Tree is created with the SWT.H_SCROLL style. V_SCROLL seems to work fine.
  • Issue 2 (Images): The tree items in the project are generally rendered with images, but some do not have such. In these cases
    the space for the image is left blank and the text is left aligned with the text of items that have images. So there is a gaping hole
    between expand symbol and text. The desired behavior would be to not leave space between the expand symbol and the text.
Has anyone encountered these issues ? And if yes, are there easy solutions ?
tibersept
[Updated on: Thu, 16 December 2010 10:32]
Report message to a moderator
Re: Tree H_SCROLL and Images [message #645092 is a reply to message #645054] Wed, 15 December 2010 14:59 Go to previous messageGo to next message
Cole Markham is currently offline Cole MarkhamFriend
Hi tibersept,
tibersept wrote on Wed, 15 December 2010 07:04
This is the standard SWT behavior. Since RAP tries to be 100% compatible with SWT (including quirks like this), this won't be changed in RAP unless it is also changed in SWT. You could ask on the SWT newsgroups and/or post a bug over there to see if they have a work around or a forthcoming bugfix.
That said, if you don't mind building RAP from source, you could probably patch it for your purposes without too much trouble.
Cole
Re: Tree H_SCROLL and Images [message #645166 is a reply to message #645054] Wed, 15 December 2010 18:33 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi tibersept,
could you try it against CVS HEAD (upcoming M4)? We replaced the native
browser scrollbars in all widgets with a new theme-able one. If the
problem persists, please open a bugzilla with a snippet to reproduce it.
Ivan
> I moved a project from RAP 1.3.0 (2010-06-15) to RAP 1.4 M3 yesterday
> and I have two issues with the new Tree widget.
> Issue 1 (V_SCROLL): The width of the item text generally exceeds the
> with images, but some do not have such. In these cases the space for
> solutions ?
> Regards,
> tibersept
Re: Tree H_SCROLL and Images [message #645267 is a reply to message #645166] Thu, 16 December 2010 10:32 Go to previous message
Member
thanks for the replies.
Concerning H_SCROLL, i did some tests against CVS HEAD and got the same results. The specific behavior can be observed
directly in the Workbench Demo, just reduce the width of views containing trees. I filed a bug here but did not look further
at why it isn't working. Tested with FF 3.6.13, IE8, Chrome 8, Opera 10.
Concerning the second issue, SWT provides events like SWT.MeasureItem and SWT.PaintItem, which are not supported in RAP
but would help to set the TreeItem content as desired in a desktop app. So this does not seem to be really a bug or an issue in SWT.
Any tips on how I can achieve something similar in RAP ( force computation of TreeItem image size for each tree item ) ?
We would like to avoid modifying the RAP sources or creating a general custom widget for trees.
tibersept
Previous Topic:IApplication versus IEntryPoint
Next Topic:How to create a "right click popup menu" for my RAP application?
Current Time: Tue Apr 16 11:57:21 GMT 2024
Powered by FUDForum. Page generated in 0.34563 seconds
