Home » Modeling » EMF » Creating Ecore models programmatically
Creating Ecore models programmatically [message #644827] Tue, 14 December 2010 11:24 Go to next message
ramlaned  is currently offline ramlaned Friend
I've searched the web for this, but couldn't find anything.
I wonder if it is possible to create Ecore models (.ecore) programmatically in Java?
For instance something like this (pseudo):
EClass c = new EClass( "SomeClass" );
c.addAttribute(...);
c.addReference(...);
model.addClass( c );
model.writeToDisk( "platform/resource/..../model.ecore");
Also, is this possible for model instances (.xmi)?
If not, what packages/classes in the EMF library could be useful to investigate further?
Take care!
Re: Creating Ecore models programmatically [message #644838 is a reply to message #644827] Tue, 14 December 2010 12:17 Go to previous messageGo to next message
I searched some more and found an answer to first question regarding .ecore files. Smile Any additional info is of course welcome.
( http://wiki.eclipse.org/EMF/Recipes#Recipe:_Generating_Your_ Own_Ecore_Model_using_a_stand-alone_Java_App)
Re: Creating Ecore models programmatically [message #644839 is a reply to message #644827] Tue, 14 December 2010 12:11 Go to previous messageGo to next message
Jonas Helming is currently offline Jonas HelmingFriend
of course this is possible. Ecore itself is defined in Ecore, so, there
should actually be no big difference between creating an Ecore or a
model instance. You can use the default EMF API for this.
Create EObject:
EcoreFactory.eINSTANCE.createEClass()
Modify References:
eClass.getEAttributes().add(yourEAttribute);
and so on.
For your instance you call your factory to create a new object:
{PackageName}Factory.eINSTANCE.create{yourModelelement}()
Cheers
Jonas
On 14.12.10 12:24, ramlaned wrote:
> Take care!
Re: Creating Ecore models programmatically [message #644943 is a reply to message #644839] Tue, 14 December 2010 21:21 Go to previous messageGo to next message
Hallvard Traetteberg is currently offline Hallvard TraettebergFriend
On 14.12.10 13.11, Jonas wrote:
> Create EObject:
> Modify References:
> and so on.
Note that you can also create the instances of this model, without
generating code, by using creating a factory with
EcoreFactory.eINSTANCE.createEFactory() and using this factory's
create(EClass) method:
EPackage pack = EcoreFactory.eINSTANCE.createEPackage();
EClass personClass = EcoreFactory.eINSTANCE.createEClass();
EAttribute nameAttribute = EcoreFactory.eINSTANCE.createEAttribute();
nameAttribute.setName("name");
nameAttribute.setEType(EcorePackage.eINSTANCE.getEString());
personClass.getEAttributes().add(nameAttribute);
pack.getEClassifiers().add(personClass);
EFactory factory = EcoreFactory.eINSTANCE.createEFactory();
EObject person = factory.create(personClass);
person.eSet(nameAttribute, "Jonas");
Thus, both models and instances of these models can be created reflectively.
Hallvard
Re: Creating Ecore models programmatically [message #645004 is a reply to message #644943] Wed, 15 December 2010 08:02 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
--------------000401010102070005010001
Am 14.12.2010 22:21, schrieb Hallvard Trætteberg:
>> Hi,
>> Create EObject:
>> Modify References:
>> and so on.
> Note that you can also create the instances of this model, without generating code, by using creating a factory with EcoreFactory.eINSTANCE.createEFactory() and using this factory's create(EClass) method:
That's not entirely correct. You can create a factory with EcoreFactory.eINSTANCE.createEFactory() but that factory can not be used to create instances of classes outside the Ecore package itself. Here is an example that *runs* without warnings or exceptions:
personClass.*_setName_**_("Person")_*;
personClass.*_getEStructuralFeatures_**_()_*.add(nameAttribu te);
pack.setName("pack");
EFactory factory = *_pack.getEFactoryInstance_**_()_*;
person.eSet(nameAttribute, "Jonas");|
Cheers
/Eike
http://www.esc-net.de
> Hallvard
Content-Type: text/html; charset=UTF-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
<blockquote cite="mid:ie8mr2$ba7$1@news.eclipse.org" type="cite">On
<br>
<blockquote type="cite">Hi,
<br>
so, there
<br>
or a
<br>
<br>
Create EObject:
<br>
<br>
Modify References:
<br>
<br>
and so on.
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
</blockquote>
exceptions:<br>
<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<!-- = Java Sourcecode to HTML automatically converted code = -->
<!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = -->
<!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3"
cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td nowrap="nowrap" align="left"
valign="top"> <code>
<font color="#ffffff">    </font><font color="#000000"> EAttribute nameAttribute = EcoreFactory.eINSTANCE.createE Attribute </font><font
color="#000000">()</font><font color="#000000">;</font><br>
<font color="#ffffff">    </font><font color="#000000">nameAttribute.setName</font><font
color="#000000">(</font><font color="#2a00ff">"name"</font><font
color="#000000">)</font><font color="#000000">;</font><br>
<font color="#ffffff">    </font><font color="#000000">nameAttribute.setEType</font><font
color="#000000">(</font><font color="#000000">EcorePackage.eINSTANCE.getEString</font><font
color="#000000">())</font><font color="#000000">;</font><br>
<font color="#ffffff"></font><br>
<font color="#ffffff">    </font><font color="#000000">EClass personClass = EcoreFactory.eINSTANCE.createEClass </font><font
<font color="#ffffff">    </font><font color="#000000">personClass.<font
color="#ff0000"><b><u>setName</u></b></font></font><font
color="#ff0000"><b><u>("Person")</u></b></font><font
color="#ff0000"><b><u>getEStructuralFeatures</u></b></font ></font><font
color="#ff0000"><b><u>()</u></b></font><font
color="#000000">.add</font><font color="#000000">(</font><font
color="#000000">nameAttribute</font><font
<font color="#ffffff">    </font><font color="#000000">EPackage pack = EcoreFactory.eINSTANCE.createEPackage </font><font
<font color="#ffffff">    </font><font color="#000000">pack.setName</font><font
color="#000000">(</font><font color="#2a00ff">"pack"</font><font
<font color="#ffffff">    </font><font color="#000000">pack.getEClassifiers</font><font
color="#000000">()</font><font color="#000000">.add</font><font
color="#000000">(</font><font color="#000000">personClass</font><font
<font color="#ffffff">    </font><font color="#000000">EFactory factory = <font
color="#ff0000"><b><u>pack.getEFactoryInstance</u></b> </font></font><font
<font color="#ffffff">    </font><font color="#000000">EObject person = factory.create</font> <font
<font color="#ffffff">    </font><font color="#000000">person.eSet</font><font
color="#000000">(</font><font color="#000000">nameAttribute, </font><font
color="#2a00ff">"Jonas"</font><font color="#000000">)</font><font
color="#000000">;</font></code> </td>
<!-- end source code --> </tr>
</tbody>
</table>
</div>
<!-- = END of automatically generated HTML code = -->
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<a class="moz-txt-link-freetext" href="http://www.esc-net.de">http://www.esc-net.de</a><br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a><br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a><br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
reflectively.
<br>
<br>
Hallvard
<br>
</blockquote>
</body>
</html>
--------------000401010102070005010001--
Re: Creating Ecore models programmatically [message #645274 is a reply to message #644827] Thu, 16 December 2010 11:25 Go to previous messageGo to next message
Thanks to all that responded to this! I've for the most part worked with instances of Ecore models, thus it's great to see that Ecore models can be created in a similiar manner.
Take care!
[Updated on: Thu, 16 December 2010 11:25]
Report message to a moderator
Re: Creating Ecore models programmatically [message #1840166 is a reply to message #644839] Thu, 08 April 2021 02:53 Go to previous message
Lesley Lee is currently offline Lesley LeeFriend
Jonas Helming wrote on Tue, 14 December 2010 12:11
Create EObject:
Modify References:
and so on.
Cheers
Jonas
> Take care!
This is the answer, and the following is my example.
		Person newPerson = CollegeFactory.eINSTANCE.createPerson();
		newPerson.setName("Bob");
		newPerson.setAge(24);
		addressBook.getPersons().add(newPerson);
Previous Topic:[CDO] Websocket transport layer
Next Topic:UML profile and EMF ecore
Current Time: Fri Oct 22 14:08:49 GMT 2021
Powered by FUDForum. Page generated in 0.02381 seconds
