Home » Eclipse Projects » EclipseLink » JPA 2 Query casting throwing exception(JPA Criteria API)
JPA 2 Query casting throwing exception [message #644286] Fri, 10 December 2010 12:09 Go to next message
James Rawlings is currently offline James RawlingsFriend
Follwing the example from http:// wiki.eclipse.org/EclipseLink/Release/2.1.0/JPAQueryEnhanceme nts I am casting the query to a subclass using the criteria API Expression.as(type). When casting the result to a Path as per the the example I get a class cast exception.
Root<Employee> empRoot = cq1.from(getEntityManagerFactory().getMetamodel().entity(Employee.class));
Join<Employee, Project> join = empRoot.join("projects");
Path exp = ((Path)join.as(LargeProject.class)).get("budget");
exception thrown..
ClassCastException: Cannot cast org.hibernate.ejb.criteria.expression.function.CastFunction (id=113) to java.persistence.criteria.Path
Can anybody help? Many thanks.
[Updated on: Fri, 10 December 2010 14:26]
Report message to a moderator
Re: JPA 2 Query casting throwing exception [message #644334 is a reply to message #644286] Fri, 10 December 2010 15:20 Go to previous message
Chris Delahunt is currently offline Chris DelahuntFriend
The error states you are using Hibernate as your JPA provider.
You need to use EclipseLink as the provider to get EclipseLink features. ie
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider >
in your persistence.xml with the EclipseLink jar on your classpath. see
http://wiki.eclipse.org/EclipseLink/Examples
Chris
Previous Topic:BigDecimal correctly persisted but not correctly loaded
Next Topic:TableGenerator Sequencing options
Current Time: Sun Jul 25 13:58:23 GMT 2021
Powered by FUDForum. Page generated in 0.02309 seconds
