Re: Acceleo Compiler [message #644054] |
Thu, 09 December 2010 09:26 |
--------------080202050103030600020007
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Maik,
This, too, is related to package registration IIRC (you're trying to
load a model which metamodel is defined as "http://" and EMF does not
find the EPackage, thus tries on the net ... or something like that,
can't recall :p).
Adding the EMF newsgroup to the CC: list so that Ed can see this and,
hopefully, give a better answer ^^.
Laurent Goubet
Obeo
On 09/12/2010 10:07, Maik wrote:
> i use the acceleoCompiler.jar calling via ant task.
> Acceleo Compiler
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2t/org .eclipse.acceleo/plugins/org.eclipse.acceleo.parser/lib/acce leoCompiler.jar?revision=1.6&root=Modeling_Project
> I get the following exception
> Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos
> ticWrappedException: java.net.ConnectException: Connection timed out:
> connect
> at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe
> mandLoadException(ResourceSetImpl.java:315)
> My ant task
> <target name="compileAcceleo">
> <acceleoCompiler sourceFolders="${WORKSPACE}/src">
> </acceleoCompiler>
> </target>
> Best regards
> Maik
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyIj5PYmVvPC9hPg0KZW1haWw7 aW50ZXJuZXQ6
bGF1cmVudC5nb3ViZXRAb2Jlby5mcg0KdXJsOmh0dHA6Ly93d3cub2Jlby5m cg0KdmVyc2lv
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------080202050103030600020007--
Re: Acceleo Compiler [message #644161 is a reply to message #644054] |
Thu, 09 December 2010 17:21 |
Ed Merks Messages: 33140 Registered: July 2009 |
Guys,
Comments below.
Laurent Goubet wrote:
> Hi Maik,
> can't recall :p).
Yes, if the package isn't registered, the logical nsURI is used as the
physical location URI.
> Laurent Goubet
> Obeo
>> Acceleo Compiler
>> connect
>> My ant task
>> </acceleoCompiler>
>> </target>
>> Best regards
>> Maik
Ed Merks
FUDForum. Page generated in 0.05231 seconds
