Re: Acceleo Compiler [message #644051 is a reply to message #644045] |
Thu, 09 December 2010 09:26 |
--------------080202050103030600020007
Hi Maik,
This, too, is related to package registration IIRC (you're trying to
load a model which metamodel is defined as "http://" and EMF does not
find the EPackage, thus tries on the net ... or something like that,
can't recall :p).
Adding the EMF newsgroup to the CC: list so that Ed can see this and,
hopefully, give a better answer ^^.
Laurent Goubet
Obeo
On 09/12/2010 10:07, Maik wrote:
> i use the acceleoCompiler.jar calling via ant task.
> Acceleo Compiler
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2t/org .eclipse.acceleo/plugins/org.eclipse.acceleo.parser/lib/acce leoCompiler.jar?revision=1.6&root=Modeling_Project
> I get the following exception
> Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos
> ticWrappedException: java.net.ConnectException: Connection timed out:
> connect
> at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe
> mandLoadException(ResourceSetImpl.java:315)
> My ant task
> <target name="compileAcceleo">
> <acceleoCompiler sourceFolders="${WORKSPACE}/src">
> </acceleoCompiler>
> </target>
> Best regards
> Maik
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------080202050103030600020007--
Re: Acceleo Compiler [message #644150 is a reply to message #644051] |
Thu, 09 December 2010 16:57 |
Ed Willink Messages: 7655 Registered: July 2009 |
Hi Laurent, Maik
EMF cannot tell whether the http:// is logical or physical, so it has to
try, unless you provide a custom URIResolver that traps net access.
[EMF used to try repeatedly for every reference; now it caches the
failure so that you only get one network failure.]
Ed Willink
On 09/12/2010 09:26, Laurent Goubet wrote:
> Hi Maik,
> can't recall :p).
> Laurent Goubet
> Obeo
>> Hi,
>> Acceleo Compiler
>> connect
>> My ant task
>> </acceleoCompiler>
>> </target>
>> Best regards
>> Maik
Re: Acceleo Compiler [message #644155 is a reply to message #644051] |
Thu, 09 December 2010 17:21 |
Ed Merks Messages: 33140 Registered: July 2009 |
Guys,
Comments below.
> Hi Maik,
> can't recall :p).
Yes, if the package isn't registered, the logical nsURI is used as the
physical location URI.
> Laurent Goubet
> Obeo
>> Hi,
>> Acceleo Compiler
>> connect
>> My ant task
>> </acceleoCompiler>
>> </target>
>> Best regards
>> Maik
Ed Merks
Re: Acceleo Compiler [message #644781 is a reply to message #644444] |
Tue, 14 December 2010 08:42 |
--------------070208040206000206020404
Hi Maik,
I am not the one who wrote this ant task and as such am not that
familiar with it myself. Maybe this message (
http://www.eclipse.org/forums/index.php?t=msg&goto=64391 4&S=b068bba0294b95a3352f2b3a4578d22b
) from Sebastien Roy will help?
Laurent Goubet
Obeo
On 11/12/2010 13:39, Maik wrote:
> Hi Laurent,
> may you can show me a example how to use the dependencies attribute in
> the acceleoCompiler ant task?
> Best reagards
> Maik
--------------070208040206000206020404--
FUDForum. Page generated in 0.03242 seconds
