Re: Problem with importtargetdefinition [message #661303 is a reply to message #661286] |
Thu, 24 March 2011 06:06 |
Sounds like the p2 cache in your workspace got corrupted somehow. Do you
get the same problem when materializing into a clean workspace?
- thomas
On 2011-03-23 23:08, Zoltán Ujhelyi wrote:
> I've successfully reproduced the same thing. I have two update sites in
> the target platform, one created by B3 (basically a filtered local copy
> of the Helios update site) and one created by Buckminster (with perform
> site.p2).
> In case of the latter site I got exactly the same exception stating,
> that a selected feature is not found.
> Contains: Unable to locate installable unit
> org.eclipse.viatra2.visualisation.feature.feature.group
> Unable to load all units for Software Site container of target
> ../buckminster36/base-local-viatra.target
> [0]Unable to locate installable unit
> However, using buckminster listsite on the repository the feature is there:
> Features:
> org.eclipse.viatra2.core.feature (VIATRA2 R3 Model Transformation
> Framework Core Components)
> org.eclipse.viatra2.core.source.feature (Source for VIATRA2 R3 Model
> Transformation Framework Core Components)
> org.eclipse.viatra2.visualisation.feature (Viatra Visualisation Feature)
> org.eclipse.viatra2.visualisation.source.feature (Source for Viatra
> Even better, if I try to use the exact same target definition (shared
> via SVN) in the IDE, I can import all targets, and set it as a target
> platform as well.
> Does anyone have a slight idea, how to avoid this problem?
> Thanks in advance,
> Zoltán Ujhelyi
Re: Problem with importtargetdefinition [message #661317 is a reply to message #661309] |
Thu, 24 March 2011 07:23 |
On 2011-03-24 08:10, Zoltán Ujhelyi wrote:
> Thanks for the quick response.
> I think, I can. I defined the task in Jenkins, where the workspace was set inside the jobs workspace, and created a copy
> of the task with a clean workspace where the issue has reappeared.
> Do you have any other idea what might have gone wrong?
> Zoltán
What does the target definition look like? In particular, are there any version constrains or filters for the feature?
What type of URL do you use to reach the repository? Is there any authentication involved? Or https? Or perhaps remote
access in a proxy limited environment? Just trying to find possible causes...
- thomas
FUDForum. Page generated in 0.02123 seconds
