Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3.0.1] Error notifying registry change listener.
[Acceleo 3.0.1] Error notifying registry change listener. [message #643561] Tue, 07 December 2010 12:46 Go to next message
Manuel Selva is currently offline Manuel SelvaFriend
Hello there,
I am starting to play with Acceleo 3 in order to automate one repetitive tasks of my daily work as Eclipse plugin developer.
In this context I want to generate several Java classes from an EMF model (xmi file) conform to a given meta model (an ecore file). This is done manually by myself during development stage, no need to programatically generate code.
Using for loops and the file tag, I successfully generated my class files for all model elements. Now I need to generate the content of the file, and for this I need an other for loop inside the file tag. After added this loop I always get many errors (crashing my workbench) of type:
"Error notifying registry change listener."
Any ideas why ? How can I solve this blocking issue please ?
Any help would be really appreciated,
Thanks in advance
Manu
[Updated on: Tue, 07 December 2010 13:05]
Report message to a moderator
Re: [Acceleo 3.0.1] Error notifying registry change listener. [message #643564 is a reply to message #643561] Tue, 07 December 2010 13:06 Go to previous messageGo to next message
After more investigations it seems it's not related to a for loop in a file tag. In fact the problem start occurring the second time i am launching my "Generate" Acceleo launch configuration.
Manu
Re: [Acceleo 3.0.1] Error notifying registry change listener. [message #643796 is a reply to message #643564] Wed, 08 December 2010 09:53 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent GoubetFriend
--------------060001080200040309090403
Hi Manuel,
This is due to us relying on OSGi's "hot removing" of bundles, but some
plugins aren't being good citizens with their extension points : when we
(Acceleo) remove said plugins, their contributions to the plugin
registry remain... and you get the error you observed.
This is a known Acceleo limitation. As we can't expect the plugin
designers to change their extension points to accept hot
plugging/removing, we need to find a way to workaround this issue ...
but don't expect this workaround to be there before 3.1M6 at least.
For the time being, your options are limited : this issue comes from
Acceleo's dynamic mode. When you launch the generator located in plugin
A, we'll walk the workspace projects in order to check whether one of
them is a dependency of A. If A or one of its dependencies is in the
workspace, and extends an extension point that presents the issue of not
being dynamic, you'll have this error. You can then :
- remove from your workspace the dependencies you don't need to be there
(if they're already installed)
- launch a runtime Eclipse and launch your generation from there (either
with only your generator project in the workspace or, even better,
having defined an action to launch the generation from a right-click, a
menu...)
This will be investigated (and, hopefully, fixed) before 3.1 goes live,
but I can't give any more precise date.
Laurent Goubet
Obeo
> Manu
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------060001080200040309090403--
Re: [Acceleo 3.0.1] Error notifying registry change listener. [message #643824 is a reply to message #643796] Wed, 08 December 2010 12:24 Go to previous message
Hi Laurent,
Thanks for your clear and complete answer.
The alternatives you mentioned are ok for now. I hope this will remain true.
Manuel
Previous Topic:[xPand] class not found org.eclipse.jface.text.BadLocationException
Next Topic:How Increment Variable in loop
Current Time: Sat Apr 13 13:52:20 GMT 2024
Powered by FUDForum. Page generated in 0.04127 seconds
