[XPand] strange failure (no viable alternative at input) [message #643074] |
Fri, 03 December 2010 17:42  |
Originally posted by: toh.fh-zwickau.de
I'm switching from XPand 0.7.2 to the current XPand 1.0.1 and get an error, which is often related with encoding issues:
ERROR | WorkflowRunner | no viable alternative at input 'Â' on line 1
org.eclipse.internal.xtend.xtend.parser.ParseException: no viable alternative at input 'Â' on line 1
Because all templates worked fine under XPand 0.7.2, I played a bit around and tried to isolate the problem. If a have a template like this, everything works fine:
«REM»
Performs the generation of javadoc comments
works not deterministic
«ENDREM»
«IMPORT gcore»
«DEFINE Root FOR MModel -»
«ENDDEFINE»
If I change just the words in the third line of the comment, so the template appears as follows, it doesn't work anymore:
«REM»
i dont understand it
«ENDREM»
«IMPORT gcore»
«ENDDEFINE»
However, I found a general workaround to move the import statement before the comment, so the template is again working correctly:
«IMPORT gcore»
«REM»
«ENDREM»
«ENDDEFINE»
This problem is somehow weird. It seams it has something to do with the multi line comment. Do you have any idea about the reason for this behavior? Personally I can live with the workaround, but interested in the cause of the problem. All templates are utf-8 encoded.
kind regards
tobi
FUDForum. Page generated in 0.07192 seconds
