load correctly an UML profile [message #642946] |
Fri, 03 December 2010 13:27 |
smaoui asma Messages: 50 Registered: July 2009 Location: Paris Saclay, France |
Member |
Hello everybody,
I tried to load an UML profile manually (in a java class):
public void registerPackages(ResourceSet resourceSet) {
super.registerPackages(resourceSet);
resourceSet.getPackageRegistry().put(UMLPackage.eINSTANCE.ge tNsURI(), UMLPackage.eINSTANCE);
// TODO If you need additional package registrations, do them here. The following line is an example for UML.
resourceSet.getPackageRegistry().put(HLAMPackage.eINSTANCE.g etNsURI(), HLAMPackage.eINSTANCE);
/* resourceSet.getPackageRegistry().put(EcorePackage.eINSTANCE. getNsURI(), EcorePackage.eINSTANCE);*/
Map uriMap = resourceSet.getURIConverter().getURIMap();
URI uri = URI.createURI(" jar:file:/export/home/charfi/Bureau/Logiciel/eclipse/plugins /org.eclipse.papyrus.marte.static.profile_0.7.1.201011231845 .jar!/ ");
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri.appendSegment("resources").appendSegment(""));
/*URI uri = URI.createURI(" jar:file:/export/home/charfi/Bureau/Logiciel/eclipse/plugins /org.eclipse.uml2.uml.resources_3.1.1.v201008191505.jar!/ ");
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri.appendSegment("profiles").appendSegment(""));*/
public void registerResourceFactories(ResourceSet resourceSet) {
super.registerResourceFactories(resourceSet);
// TODO If you need additional resource factories registrations, do them here
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.PROFILE_FILE_EXTENSION, HLAMFactory.eINSTANCE);
for the Ecore profile, this works very well, I can print the profile name, the used stereotype name etc.
when I try to load the HLAÙ profile (sub profile of the MARTE profile), and print the profile name I get this:
org.eclipse.uml2.uml.internal.impl.ProfileImpl@121fd61 (eProxyURI: pathmap://Papyrus_PROFILES/MARTE.profile.uml#_yNSZIAPMEdyuUt -4qHuVvQ)
instead of :
org.eclipse.uml2.uml.internal.impl.ProfileImpl@1df7735 (name: HLAM, visibility: <unset>)
the MARTE.profile.uml is located in the resources folder of je jar file: jar:file:/export/home/charfi/Bureau/Logiciel/eclipse/plugins /org.eclipse.papyrus.marte.static.profile_0.7.1.201011231845 .jar
just like the Ecore.profile.uml which is located in the folder profiles of the jar file jar:file:/export/home/charfi/Bureau/Logiciel/eclipse/plugins /org.eclipse.uml2.uml.resources_3.1.1.v201008191505.jar
did I miss something to load corectly the profile, cause the (eProxyURI: pathmap://Papyrus_PROFILES/MARTE.profile.uml#_yNSZIAPMEdyuUt -4qHuVvQ) means that the EMF did not recognize my profile although the refernce is the rignt reference of the HLAM profile.
thank you very much
Asma.
FUDForum. Page generated in 0.23878 seconds
