Re: Precompiled JSPs full of ${..} [message #754210 is a reply to message #682099] |
Tue, 01 November 2011 12:39 |
Hi Friends,
Please help me How to create PAR project in virgo server environment. as of now i was create par file just add two project then export par file but did not run.
This is my error report:
[2011-11-01 17:30:10.824] TCP Connection(2)-127.0.0.1 org.eclipse.virgo.medic.eventlog.default ME0003I Dump 'serviceability/dump/2011-11-01-17-30-483' generated
[2011-11-01 17:30:10.835] TCP Connection(2)-127.0.0.1 org.eclipse.virgo.medic.eventlog.default DE0002E Installation of par 'samplemiddletier-par' version '1.0.0' failed. java.lang.UnsupportedOperationException: Cannot open an input stream for '/home/sample/server/virgo-web-server-2.1.0.RELEASE/work/org.eclipse.virgo.kernel.deployer_2.1.0.RELEASE/staging/samplemiddletier-par-1/bundle/samplemiddletier-par-1-samplemiddletierservice-dm/0.0.0/samplemiddletierservice-dm.jar/META-INF/MANIFEST.MF' as it does not exist
at org.eclipse.virgo.kernel.artifact.fs.internal.FileArtifactFSEntry.getInputStream(FileArtifactFSEntry.java:59)
at org.eclipse.virgo.kernel.install.artifact.internal.ServiceScoper.loadManifest(ServiceScoper.java:186)
at org.eclipse.virgo.kernel.install.artifact.internal.ServiceScoper.loadBundleManifests(ServiceScoper.java:175)
at org.eclipse.virgo.kernel.install.artifact.internal.ServiceScoper.doScope(ServiceScoper.java:156)
at org.eclipse.virgo.kernel.install.artifact.internal.ServiceScoper.scope(ServiceScoper.java:88)
at org.eclipse.virgo.kernel.install.artifact.internal.PlanScoper.scope(PlanScoper.java:137)
at org.eclipse.virgo.kernel.install.artifact.internal.StandardPlanInstallArtifact.scope(StandardPlanInstallArtifact.java:175)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.internal.ScopingTransformer.processScopedPlanInstallArtifact(ScopingTransformer.java:50)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.internal.ScopedPlanIdentifyingTreeVisitor.visit(ScopedPlanIdentifyingTreeVisitor.java:32)
at org.eclipse.virgo.util.common.ThreadSafeArrayListTree.visit(ThreadSafeArrayListTree.java:165)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.internal.ScopingTransformer.transform(ScopingTransformer.java:41)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.internal.TransformationStage.doProcessTree(TransformationStage.java:55)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessTree(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessTree(CompensatingPipeline.java:72)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:271)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:151)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:123)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:190)
at org.eclipse.virgo.kernel.deployer.management.StandardDeployer.deploy(StandardDeployer.java:52)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at com.sun.jmx.mbeanserver.ConvertingMethod.invokeWithOpenReturn(ConvertingMethod.java:167)
at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIntrospector.java:96)
at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIntrospector.java:33)
at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(MBeanIntrospector.java:208)
at com.sun.jmx.mbeanserver.PerInterface.invoke(PerInterface.java:120)
at com.sun.jmx.mbeanserver.MBeanSupport.invoke(MBeanSupport.java:262)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:836)
at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:761)
at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RMIConnectionImpl.java:1427)
at javax.management.remote.rmi.RMIConnectionImpl.access$200(RMIConnectionImpl.java:72)
at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOperation.run(RMIConnectionImpl.java:1265)
at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOperation(RMIConnectionImpl.java:1360)
at javax.management.remote.rmi.RMIConnectionImpl.invoke(RMIConnectionImpl.java:788)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:305)
at sun.rmi.transport.Transport$1.run(Transport.java:159)
at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:535)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:790)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:649)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
[2011-11-01 17:30:10.835] TCP Connection(2)-127.0.0.1 o.e.v.k.m.i.deployer.ModelInstallArtifactLifecycleListener Processing install failed event for bundle 'samplemiddletier-par-1-samplemiddletierservice-dm' version '0.0.0'
[2011-11-01 17:30:10.839] TCP Connection(2)-127.0.0.1 org.eclipse.virgo.medic.eventlog.default DE0003E Install failed for bundle 'samplemiddletier-par-1-samplemiddletierservice-dm' version '0.0.0'.
[2011-11-01 17:30:10.839] TCP Connection(2)-127.0.0.1 o.e.v.k.m.i.deployer.ModelInstallArtifactLifecycleListener Processing install failed event for bundle 'samplemiddletier-web' version '0.0.0'
[2011-11-01 17:30:10.843] TCP Connection(2)-127.0.0.1 org.eclipse.virgo.medic.eventlog.default DE0003E Install failed for bundle 'samplemiddletier-web' version '0.0.0'.
[2011-11-01 17:30:10.843] TCP Connection(2)-127.0.0.1 o.e.v.k.m.i.deployer.ModelInstallArtifactLifecycleListener Processing install failed event for par 'samplemiddletier-par' version '1.0.0'
[2011-11-01 17:30:10.847] TCP Connection(2)-127.0.0.1 org.eclipse.virgo.medic.eventlog.default DE0003E Install failed for par 'samplemiddletier-par' version '1.0.0'.
[2011-11-01 17:30:10.850] TCP Connection(2)-127.0.0.1 org.eclipse.virgo.kernel.deployer.management.StandardDeployer Exception filtered from JMX invocation java.lang.UnsupportedOperationException: Cannot open an input stream for '/home/sample/server/virgo-web
[Updated on: Tue, 01 November 2011 12:44] Report message to a moderator
FUDForum. Page generated in 0.05002 seconds
